Just now realizing I am going on three months with my suspension hanging out on the floor of my gym. Hopefully can find some mod time in the next few weeks and show some before and afters.
I will be next month.Have any of you installed 4dr Bilsteins on your 2dr? I'm thinking about it, the 200lbs difference between the two models can't be that big of a deal right? I need to get rid of these Hitachi shocks
Put your ride opinion out there please. I am interested to know if it really hurts. Or maybe helps even more with the diving...I will be next month.
I have the Non-sasquatch Badlands suspension on my 2021 Bronco OBX, and yes, it definitely dives less under braking with the Bilsteins.Put your ride opinion out there please. I am interested to know if it really hurts. Or maybe helps even more with the diving...
Yeah a little taller but you lose that height in suspension travel because its just a bump stopI found basequatch take-offs from a local, which I think are half inch higher than the BL Bilsteins. Looks like I need to find some 34/35's to match the look.
No. The inside diameter of the spring is to small to fit over the Sasquatch shock. You need to buy takeoffs that come with the springs. Or buy springs separately. I bought the whole assembly for $500.Howdy - dumb question, but i didnt see it addressed over the last 6 pages so ill ask:
I found some stock badlands shocks for my big bend (non-sas). Is it a simple swap and can i use my same stock springs? From what ive read, the badlands non-sas suspension is around .6 inches higher than base and wasnt sure if my springs would work with that.
Thanks for the input.
Just to clarify - these are badlands takeoffs that ARE NOT a sasquatch. Just the stock badlands springs which are Bilstein and taller than base. Are you saying these will still not work with my stock Big Bend springs?No. The inside diameter of the spring is to small to fit over the Sasquatch shock. You need to buy takeoffs that come with the springs. Or buy springs separately. I bought the whole assembly for $500.
Pretty sure that you need to change both, but you can give it a try. I think the sasquatch and non-sasquatch Badlands springs for the Bilsteins are the same, but not the Hitachi springs. However, they could fit.Just to clarify - these are badlands takeoffs that ARE NOT a sasquatch. Just the stock badlands springs which are Bilstein and taller than base. Are you saying these will still not work with my stock Big Bend suspension?
This picture answers your question. No they won't work. Broncos with Hitachi shocks use 5100's because their spring fits over it, Sasquatch and badlands order 6100's because they have the bigger springs.Just to clarify - these are badlands takeoffs that ARE NOT a sasquatch. Just the stock badlands springs which are Bilstein and taller than base. Are you saying these will still not work with my stock Big Bend springs?
