Borne Off-Road Wheel Spacers
rtaylor
R
ID
19Raptor, 22Bronco
How much poke are you seeing with this setup?
For 0.75" spacers, the widest part of the 37" rubber sticks out about 1/2" on rear and 1/4" in front for sasquatch flares.
Not the best photos:
JTr717
JT
Indalantic, FL
2022 Bronco 4D Big Bend Area 51
@Mishimoto
I am ready to pull the trigger on these now but have questions.
Stock big bend wheels (w/35x12.5) will both the 1" and 1.20" black spacers fit without triming studs?
Are both in stock?
Advice on how far out this would poke on non-sas with 35x12.5 stock big bend rims?
Thanks
Mishimoto
Mishimoto
New Castle, Delaware
F-250
@Mishimoto
Are both in stock?
Thanks
Yep, both sizes would fit your wheels no problem without any trimming needed! I also just checked and we are currently out of stock on those sizes, BUT our restock is due this week so they'll be back in stock very soon
As for the amount of poke you'd see, it's tough to give anything exact since we haven't fit our spacers on a setup of that size, but, just from some comparing and research, it would likely be similar or a little more poke than the 2" spacer on our Bad Lands (33x11.2) that's on the first post
-Nick
JTr717
JT
Indalantic, FL
@Mishimoto
Thanks for the fast reply, do you have the 1.40" black spacers in stock?
FairPlayInc
Billy
New York
2022 Bronco Wildtrak
@Mishimoto , so to clarify, which of your spacers require NO trimming of studs for stock SAS equipped Broncos?
Mishimoto
Mishimoto
F-250
Hi @FairPlayInc one of the primary "no trimming" factors is if there is a 'pocket' backside of your wheels. That 'pocket' helps accept the stock studs protruding past the wheel spacer face. So if your wheels have that 'pocket,' you should be good with our thinnest 1.00" spacer.
Hope this helps!
- John P
JimmyD
Georgia
2019 Ford Ranger XLT FX4/2019 Mustang Ecoboost
Hi Nick, Do you sell just one spacer for the rear spare tire carrier ? Bought new set of wheels that have a -12 offset. Thanks
mattymik
Houston, TX
2019 Honda Odyssey, 2023 WildTrak
I’m confused by this. But I may be wrong in my confusion:
Can you explain why you need a spacer for the spare? especially one with negative offset?
JimmyD
Georgia
My bad... The wheel will fit just fine. I was the one confused
mattymik
Houston, TX
I’ve never before had a car where I worried about wheel offset. So I wasn’t sure myself, but have some low-offset wheels on order, so I wanted to make sure I didn’t have this wrong 😑
CtSASBronco
CT
Jeep Wramgler
Any idea of when to expect ship time for 1.5" spacers?
FairPlayInc
Billy
New York
@Mishimoto , 1” ordered! I got an email about back order though. Said 8-10 weeks. Is that still accurate?
Mishimoto
Mishimoto
F-250
Hey @CtSASBronco - Roughly sub-two weeks out from ship. An important thing to remember is that ordering puts you in line... so the earlier you get an order in, the earlier you will ship compared to if you waited.
Hey @FairPlayInc - thanks for the order! From what I see in our systems, we are way less than 8-10 weeks to ship current orders. I'd slate this as closer to a sub-two week time frame.
- John P
