Bottle jack won't lift front tires?
Stonetree
Ron
Pittsburgh
2021 Bronco Wildtrak
I bought the 6 ton Safe Jack starter kit. It came with the bottle jack, 3 inch extension, flat top, and curved axle cradle. I wanted to just try it out today. There was no problem lifting the back tire at the axle. Then I tried to lift the front tire using the 3 inch extension and the flat top. Came to about a half inch below the frame. I positioned it at the front Jack point where the arrow is on the frame. I pumped the bottle jack to it's limit and the front tire didn't come off the ground. I think it was close, but the jack just didn't extend enough to overcome the tire droop. There isn't room to use a longer extension. Do I need to use the bottle jack at a different front location? If so, where?
jh3113
Jake
Phoenix
Subaru Outback
i just used my Husky 3 Ton floor jack to rotate all my tires, had no problems with lift. the bottle jack might not be giving enough lift.
Beach_Bum
Ken
St. Augustine, FL
@broncorik has bought the Saf-T-Jack. Maybe he can help from his experience.
drew707
Ford Explorer
Under the control arm
Front control arms are aluminum and are explicitly advised against lifting or jacking on them. But I’ve done it a bunch so yeah.
The Bronco just sits high with a lot of suspension drop. Longer spacer or taller jack might be needed.
Bonnie6G
Kyle
Denver
Badlands LuxSquatch
Yeah, I noticed it was an issue when I swapped my wheels. The safejack had juuuuuust enough clearance to get the OEM wheel off in my garage, but the new wheel needed another 1/2” or so. I wound up using another floor jack to lift the control arm a touch (against all Ford warnings). To make the safejack work, I think you’ve got to get that screw on the top of the piston just the perfect amount exposed before adding the extension and flat top. If you don’t scrape along the frame getting the jack in place, screw it out a touch more and try again.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Keep a chunk of 4x6 or 6x6 wood around to get the extra needed.
How about ramming them into and up a stump? Probably not recommended either.
Ford Bronco Bottle jack won't lift front tires? 277940182_3426274284358076_3869412594765321245_n
Oldhippie
Barry
Santa Cruz, Calif.
Love how the lowest front suspension part (A-arm) on a “off road” designed vehicle is made of weak aluminum that should not be used to lift a tire...Ford tough my ass...
Gtrekker
Gary
NJ
How on earth did you do that!!!???? Having a slow day on the trail and thought... Did you save your drink? LOL
Tricky Dick
Dick
PNW
I just zoned out I guess. And of course it was approximately 2 seconds after raving to my wife about how great the front camera was for seeing everything.
SuperDave150
Lubbock, TX
Ford F-150, Ford Edge
Much better to have a jack that is a little short (but will easily fit under the vehicle when the tire is flat & terrain is uneven), then too tall and you can’t get it under the vehicle. Use a rock or block of wood as a spacer, or move the vehicle a few feet to a better location.
Gtrekker
Gary
NJ
Heck, then that's what did it!!! You can "NEVER BRAG" how good something is to the wife (unless it's her). Women have long history of training n experience to pop our bubbles. LOL
Her fault!!!
noliveaxle
john
Riverside, Calif
2015 jku rubicon
It not weak. The front a-arm is just not a secure location to lift from. Not safe.
Vantcrst
CA
92 Ford F-150, Mercedes 4x4 Sprinter Van,
That is what I like to see someone setting a good example for the rest of us. Always use jack stands when working under your vehicle.
