I’m in the Get off my Lawn and give me a mechanical backup I can trust club.
Would much prefer a hand brake.
Well, the corollary to you don't want to talk to the techs is that the techs don't want to talk to you either. It's their job to be fixing vehicles in the shop, it's my job to handle the customer and coordinate the repair. The reason I took offense to be labeled the 'technician's secretary' is that I have a ton of technical knowledge and experience regarding Ford repairs. If you want a technical explanation I will provide it. That's what I'm getting paid to do, and the techs are getting paid to perform work. Taking the technician's time to speak with a customer essentially means they don't get paid for that time.While I respect your position, and the fact that some people may need a liason. I personally would rather speak to the techs, salty or not. You want salty, I spent 23 years serving in submarines, I can match salty and then some.
Being a technician (albeit electronics and submarine stuff, its all similar) myself, I want to hear it right from my peers. I don't trust a 3rd party.
As far as the OP, I unfortunately missed out on a manual due to them being balanced out for the year so I have an automatic; but I for one do not like the electronic E brake in either my wife's sport or my OBX. I have had a couple times in the past where I had a brake line fail, and I have had to use the ebrake to stop. HTF do you do that with the electronic E brake?
There's more holding power in 1 than 2, 3, 4 etc.I'm not sure why you have anxiety, you can hear the parking brake apply when you pull the switch (or at least I can, and I have crappy hearing thanks to serving with an artillery regiment lol)
Either way, park with it in 2nd or 3rd gear (apparently the compression isn't low enough to hold the vehicle in 1st, or so I believe I read here somewhere) and stop living your life worrying about what might never happen.
I too would have preferred a mechanical parking brake, but I think you're worrying about nothing, personally.
Yeah that other guy shouldn't be giving any advice if he doesn't understand gear reduction. The amount of misinformation spread on these forums in an age where you can look up everything about anything in seconds is amazing.There's more holding power in 1 than 2, 3, 4 etc.
To move 100ft, first gear requires the engine to spin the most amount of times.
I can understand this. If you have the knowledge and can explain it, then that's fine. Typically in my line of work while I was in and now that I am out and building the same thing I served on, the liason just spews the party line and really cannot answer the deep technical questions.Well, the corollary to you don't want to talk to the techs is that the techs don't want to talk to you either. It's their job to be fixing vehicles in the shop, it's my job to handle the customer and coordinate the repair. The reason I took offense to be labeled the 'technician's secretary' is that I have a ton of technical knowledge and experience regarding Ford repairs. If you want a technical explanation I will provide it. That's what I'm getting paid to do, and the techs are getting paid to perform work. Taking the technician's time to speak with a customer essentially means they don't get paid for that time.
I know how an ABS solenoid block is supposed to work in normal situations, but I do not know if today's tech has a way to sense a catastrophic loss of pressure and shut that lines valve to preserve fluid to the remaining brakes. I know that the older master cylinders would move a plunger to limit flow on unequal pressures, but still, once the fluid is gone and the pedal is on the floor or unresponsive, then feathering the ebrake was the way to stop. Your right that the electric E brake won't cut it because you can't feather it.Theoretically even if a brake line fails you should still have sufficient stopping power on regular brakes. If you don't then you're SOL because the e-brake isn't going to do it.
And this surprises you?Yeah that other guy shouldn't be giving any advice if he doesn't understand gear reduction. The amount of misinformation spread on these forums in an age where you can look up everything about anything in seconds is amazing.
If I had a MT, I would definitely worry.How do you guys live, you worry this much about everything? Another post just to make a post - this recall doesn't include Bronco.
Right on, a manual brake gives the driver control over the situation.Your right that the electric E brake won't cut it because you can't feather it.
Agree zombie, thanks for the tip on 2nd/3rd gear. I usually leave it 1st and pull up the E-brake. The brake as designed make's the cockpit look cleaner and provides more room for a small space 4x4. A non-issue, but sometimes I do forget to pull it up. Tommy BroncI'm not sure why you have anxiety, you can hear the parking brake apply when you pull the switch (or at least I can, and I have crappy hearing thanks to serving with an artillery regiment lol)
