4.1 with torsen is an option on the ford site, that is what i meantAll Raptors come with short bed >> 5'6" and it only comes with 4.1 ... there is no choice
The Raptor's mechanical LSD gives it an advantage in bad weather conditions and during acceleration where you wouldn't have the rear locked. There's been no mention of limited slips on the Bronco, so it's either an open diff with the computer using the brakes to shuffle power around, or it's locked.The bronco will also have AWD
“It also has "4A" ... in 4A, when it detects lack of traction to the rear wheels then it will engage AWD in that the front wheels will get power.”I am not sure what you are talking about BUT the Raptor has rear wheel drive as the default. And then you have the option to put it into 4WD. It also has "4A" ... in 4A, when it detects lack of traction to the rear wheels then it will engage AWD in that the front wheels will get power.
Based on my understanding, the Bronco will be the same with:
2H >> rear wheel
4H >> 4wd .. never do this on dry roads
4L >> only when extreme traction is needed
4A >> this is awd on the fly
Yes that is auto 4wd which is far removed from All wheel drive.
All wheel drive is always 60/40 split, it is a proactive system
Auto 4 wheel drive is 50/50 split only for a couple seconds when slip is detected it is a reactive system.
Okay and? GM has done this exact same thing since 2002. It’s still not AWD by any stretch.I understand .. BUT 4A .. the way Ford designed is better .. why? It only turns 4 wheels when it needs it which results in better fuel economy.
I’m talking about real truck based transfer case AWD systems not car based, those are almost all huge POS.The majority of AWD systems are reactive too. Most of them are front wheel drive until slipping is detected and then power gets sent to the rear. There are some exceptions like Subaru, etc
Does it have merit? Sure, in fact I have a lot of experience with auto 4wd, I also have a lot of experience with true 60/40 AWD. They both have their uses but functionally one is clearly proactive and the other is reactive.
Functionally speaking an AWD truck send the power to the front axle a split second before the rear axle.
Auto 4wd does not send power until slip is detected. Which means engine power must be retarted at that time if too much throttle is occurring.
Your analogy about being on a snowy road has an issue. If your driving along at 50MPH and your rear end starts slipping it’s already too late for your front end to save the day. That’s 99% in the tires.
You guys actually had me really excited for a second I thought the Raptor actually had true AWD. AWD can be very fun in a large truck.LOL! I am not saying to flip it to 4A when you are already in the ditch.
I am telling you that it works great. Actually there are raptor guys who have tuned their trucks and engage 4A when they want ultimate traction .. like at the drag strip
OK ... you win!
I don't think Bronco has AWD. The 4A for bronco is only on-demand switching between 2H/4H. Not true full-time AWD with split front/rear torque like the 2017+ Raptor's 4A mode.The bronco will also have AWD
The 2017+ Raptor has true AWD (computer-controlled split front/rear torque and front torsen).You guys actually had me really excited for a second I thought the Raptor actually had true AWD. AWD can be very fun in a large truck.
It enables the auto 4H mode. On wheel slip it switches to 4H.what is the 4A switch for then?
Articles on 2017+ Raptor's dual-mode AWD:It enables the auto 4H mode. On wheel slip it switches to 4H.
For 2017+ Raptor, they reused the older dash switches and didn't change the label. On older Raptors, 4A is Auto4h. On newer Raptors it is AWD.
