Hey guys, I'm alive and well. I taught our band camp last week, 14 hours a day Mon-Fri. I was quite busy.
A blacked out Transit didn't abduct me in the middle of the night or anything.
Things are not great. Commodity issues far beyond the MIC tops have exploded, the chip shortage has finally reached the Bronco supply chain, and nobody really has any good answers at this point. As bad as the issues have been up to this point, this is worse.
Things are so fluid and changing so quickly, by the time I get scraps of new info it's quite likely outdated. If there's one little glimmer of good news, it may just be that the planned volume and availability of the dealer stock 4 door soft top units is quickly trending downward. After all, you can't build the "less desirable" units if you can't build anything at all.
Edit to add: My inbox is crammed with a metric ton of unread messages. If you're waiting on a reply, I'll try to get thru those in the next few days.
Q&A
You're good.
Update 8/10:
LOTS of discussion here, and some of the options being brought up jive with *possibilities* being considered. AFAIK, there isn't a firm decision one way or another. All FEs will be built out in MY21 (and honestly those still awaiting a VIN and scheduling shouldn't be waiting too much longer). Some more MIC MY21s are probably going to be built, but I doubt we'll see them any appreciable numbers.
The main thing to watch is scheduling both this week and next (assuming they both end up happening as scheduled). How many members here will see their non-FE MIC units scheduled? If we see many (any?), that's a decent sign. I don't think we will.
Another kick in the sack is that from everything I've been told none of the purgatory units are awaiting any type of inspection any longer. They're just stuck waiting on solution(s).
I've caught wind of several alternatives being considered... some more drastic than others.
Q&A
In all honesty, FE reservation holders are the only ones who should feel super confident about much of anything at this point.@PREMiERdrum, how do you see this impacting those of us with FE window stickers and build dates for this week? My blend date is 8/11.
You're good.
To my knowledge, none of the purgatory holds are waiting on chips. MAP hasn't built any Broncos without chips awaiting further installation as other Ford plants have. I've heard of some proposals but nothing that's started yet.Good to see you alive and well . Any updates on the Broncos still sitting at MAP since June? Are they waiting on chips?
No, emphatically. Hasn't happened, isn't happening, won't happen.@PREMiERdrum - If we have build waiting on the MAP lot for a roof but have chips, there's no reason to think that Ford will start using them as a pick and pull for new builds, is there? Steal a part from an already waiting build to kick out a freshly made one. God I hope not!
Update 8/10:
Not likely, which is the biggest holdup right now. The backlash for widespread delivery of shitty tops compounded by the freight costs to deliver thousands of new tops and payouts to dealers for installing them... it's not a path they want to fo down. Unfortunately, but unsurprisingly.@PREMiERdrum - any thought to Ford shipping MICs to dealers with “bad” tops and doing an extended warranty campaign on them? I have to imagine this would be easier than replacing them through MOD centers at MAP and taking up all that room.
