Aw yeah!!!One step closer…tires tomorrow..suspension next Sun/Mon.
Just tires:
Really hoping the Badlands Sasquatch (2.7 auto) takeoffs fix the rake on my Black Diamond (2.3L manual). Rear tire looks smaller. Pretty wild. I’ve seen this in other photos - it’s less noticeable in person. Just would like the wheel well spacing to even out.
@kodiakisland - rereading this thread in preparation of swap this weekend. What’s this you say about needing a sawsall to swap in the Camburg trailing arms?
Looks good. Definitely drop the lower control arm up front to make it easy. Leave the upper alone.Rears are in! Fronts tomorrow…and it’s gonna be 22-27°F. Yay.
Hey, I have the same build! What tires did you go with?Just tires:
Toyo AT3 285/75R17. They’re fantastic. Psyched to run them through their paces.Hey, I have the same build! What tires did you go with?
I have the same setup as you - what all did you order to do the full swap? Thank you!Sharing success swapping the OB with SAS takeoffs. Thank you @flip for leading the charge on this!
Before & After:
Just the struts & wheels. The upper control arms and rear sway bar were the same on the stock OBX setup vs SAS (we confirmed with the part number). I had those all on hand to replace but didn't end up needing to.I have the same setup as you - what all did you order to do the full swap? Thank you!
I have a OBX 4 Door 2.7 no tow - does that effect which springs to get? Sorry I am so new to this and I don't want to order the wrong ones!Just the struts & wheels. The upper control arms and rear sway bar were the same on the stock OBX setup vs SAS (we confirmed with the part number). I had those all on hand to replace but didn't end up needing to.
I matched engine size & tow of the unit from where mine came. If you're riding with a 2.7L, you don't want a set from a 2.3L.I have a OBX 4 Door 2.7 no tow - does that effect which springs to get? Sorry I am so new to this and I don't want to order the wrong ones!
Rotate tires and re-assess.@flip I have noticed some added vibration, which seems to be most noticeable 35-45 mph. Is that just due to the M190 axles and non-sas rack? Or should I be looking at something else?
I rowed through the gears & seems to be consistent not really being specific to one gear or another. Tires are factory balanced & everything is aligned to Ford specific.
Unless there's a bad CV joint or tierod starting to go bad, I'm out of ideas.
