Did your “full-sized” Wildtrack come with an engine block heater?My full-sized Bronco Wildtrak 2022, will not start. The battery is fine it attempts to start but never fires up. Is anyone else having this issue? Seems like it just isn't getting fuel.
BSA oath (promise) also includes:Did your “full-sized” Wildtrack come with an engine block heater?
My $26K Base came with it. It was a $95 option. You have probably spent way more than that already. Boy Scout motto = Be Prepared.
I’m not sure what makes a Wildtrak “full-sized”, maybe that’s the model with no engine block heater.
BSA does just fine looking bad for themselves. Don't use them as a shield to be a jerk to OP."To help other people at all times;"
In the days of old I would agree w/ the starting fluid but on these new vehicles I'm not sure it's a great idea but I could be wrong.Maybe I'm to old, but the way it uses to work is engines only needed 3 things to run... Air, fuel, and spark (well and compression but that's a different story)
Air... Unless you have a rat build a nest in your intake is a non issue and chances are it would start just not run well.
Fuel...this one is easy to determine with a can of starting fluid. So many people skip this and I don't understand why because it's so simple. Spray some starter fluid into your intake, if it starts then dies you have a fuel problem.
Spark.. with all the new electronics it is hard to find the fault. And with no distributor and no spark plug wires now, it's hard to test. This one you tend to rule out by process of elimination of the other 2.
My long winded suggestion is Starting fluid will tell you if it's electronics or fuel? (Or have things changed so much Starting fluid doesn't work anymore?)
Hi there! Will you send us a message with your VIN and your local Ford dealer? I can look into things on my end.My full-sized Bronco Wildtrak 2022, will not start. The battery is fine it attempts to start but never fires up. Is anyone else having this issue? Seems like it just isn't getting fuel.
It did come with an engine block heater. The messed-up thing about that is one, it didn't work, and 2, it really wants 220v, so plugging it up to a normal 110v, it only gets the output, which is ok at best. It did work ok when the temps rose. I have a strong feeling it was just bad gasoline.Did your “full-sized” Wildtrack come with an engine block heater?
Your post does not make sense, but whatever.It did come with an engine block heater. The messed-up thing about that is one, it didn't work, and 2, it really wants 220v, so plugging it up to a normal 110v, it only gets the output, which is ok at best. It did work ok when the temps rose. I have a strong feeling it was just bad gasoline.
