- Ken
- Aug 12, 2020
- 28
- 6,199
- 19,502
- St. Augustine, FL
- 2022 Black Diamond Bronco, 2023 Outerbanks Bronco
- Black Diamond
It's a shame they didn't leave the purple light in Michigan.This is from the Orlando Show's facebook page. I'm sure it's at the show. If you look at the background you can see a GMC sign.
Will look for your feedback. Hopefully they have the OBX fisherman edition. That has a standard duty suspension like the Big Bend, Black Diamond, etc. Keep in mind the OBX tire is 32.1" x 10.0". For guys looking to upgrade to 32.7-33.2" x 11.1-11.2" that means we need at least .6" of additional clearance in ALL areas between the tire and steering knuckle, and .6" vertical clearance from the top of the tire to the bottom lip of the control arm (only if it ends up overlapping the larger tire). Keep that in mind as you photograph, and run you hand behind the tire to get a feel for the steering knuckle.Got you covered ...
En route! .. it better not be roped off for access... the commercial says otherwise. .. if it is I'm going full WWE mode ... off the top rope or from under with a steel chair ...Will look for your feedback. Hopefully they have the OBX fisherman edition. That has a standard duty suspension like the Big Bend, Black Diamond, etc. Keep in mind the OBX tire is 32.1" x 10.0". For guys looking to upgrade to 32.7-33.2" x 11.1-11.2" that means we need at least .6" of additional clearance in ALL areas between the tire and steering knuckle, and .6" vertical clearance from the top of the tire to the bottom lip of the control arm (only if it ends up overlapping the larger tire). Keep that in mind as you photograph, and run you hand behind the tire to get a feel for the steering knuckle.
If you have your fingers in the photos, you could measure the width of your finger with a ruler when you get home so we could back into the dimensions. Ie is the clearance behind the tire one thumb, or an index finger plus a middle finger. Etc. Sounds crazy but thats what I did when I tested out the ranger.
God speed! Thank you.En route! .. it better not be roped off for access... the commercial says otherwise. .. if it is I'm going full WWE mode ... off the top rope or from under with a steel chair ...
Please confirm vehicle will be there Sunday prior to being escorted out by security ?En route! .. it better not be roped off for access... the commercial says otherwise. .. if it is I'm going full WWE mode ... off the top rope or from under with a steel chair ...
Looks like I'll be bringing a telescope to get that closer look.Wont let me near it ... so do I go over or under ... ?
