Can you lower rear of bronco 1 inch?
Broncola
Hawaii
Element, ‘75 Bronco widow
+1 on that! Not sure what it is, but it almost looks squacthed and I prefer non-sas! Is that the KM3s! The front looks just right, though! I’m getting a base 2-door so I have more options to get it just right.
I get what you’re trying to do. (y) If you could drop the rear an inch to level it out, it would have a nice look with 33s. Going up will make your tires look small.
Erock
US
2018 F150 Alpine edition
You don’t gotta use shorter springs, only a lower rate spring. The lower rate will allow for more initial compression.
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
I don't think anybody has deciphered spring rate and length differences yet but the B6G suspension thread says there are 6 different rear spring part numbers regardless of trim or shock type. If yours has the tow package then maybe non-tow springs would do what you want since @LEGEND says the tow ones get a little lift in the rear. Rake on a Bronco, especially 2-door, is not a good look to me so I support your mission. (y)
