- Matt
- Apr 3, 2023
- 4
- 67
- 97
- Pacific Northwest
- 2023 Bronco Black Diamond / Tesla Model 3
- Black Diamond
I guess I did something wrong. I put my bronco into neutral tow mode while trying to pop the center console (I was installing a gmrs radio). I had to put the shifter in neutral to get it off, and I thought (perhaps stupidly, also to learn how it works) neutral tow mode would be safer.
I also had the battery disconnected, just be safe. I may have reconnected the battery before hooking up the center panel connections.
Anyway I hooked up Forscan to it, and was able to reset most DTCs, however this one keeps coming back:
Anyone know what things I should check? Signal Invalid sounds like a loose connection somewhere?===IPMA DTC U0418:86-AF===
Code: U0418 - Invalid Data Received from Brake System Control Module 'A'
Additional Fault Symptom 86):
- Signal Invalid
Status (-AF):
- DTC Present at Time of Request
- Malfunction Indicator Lamp is On for this DTC
Module: Image Processing Module A
Freeze Frame #1:
-EVENT_TIME: 18254933 s (Wed Feb 21 22:12:10 2024) - Event time
-TOTAL_DISTANCE: 2661 km - Total Distance
-MODULE_VOLTAGE: 11.8 V - Control Module Voltage
-OUTDOOR_TEMPERATURE: 12 °C - Outside temperature
-ECU_POWER_SUPPLY: 11.6 V - ECU Power Supply Voltage
-ECU_INTERNAL_TEMPERATURE: 24 °C - ECU Internal Temperature
===END IPMA DTC U0418:86-AF===
