yes, it is rotational noise, and frequency went up with speed.This sounds very similar to what mine had from day one. It turned out to be an incorrectly installed backing plate for the brake. It was a rotational noise and frequency went up with the speed. Not saying that's the exact cause for you, but does sound like it.
Taking off and putting on your wheel can easily cause the dust cover to get bent and make contact with a brake rotor — I would take that wheel back off and ensure nothing is coming in contact with the wheel or rotor.yes, it is rotational noise, and frequency went up with speed.
But I can only hear it from outside.
My tire is flat, so I replace it spare tire on passenger rear.
And my friend notice it from outside. (I am not sure if this happens before or after my tire got flat)
Could it be broken after my tire got flat on the highway? I replace it after driving to safety spot about less than 0.2 mile.
How did you fix the backing plate for the brake?
Hi there! Will you send us a message with your VIN and dealership info? I would like to look into your Bronco's noise issue on my end.Is this normal to have a clanking noise? (Only hear it from outside)
This happened to me. It's bend really easily.Taking off and putting on your wheel can easily cause the dust cover to get bent and make contact with a brake rotor — I would take that wheel back off and ensure nothing is coming in contact with the wheel or rotor.
What was the fix?Is this normal to have a clanking noise? (Only hear it from outside)
