. [Closed due to abandonment by OP]
Status
Not open for further replies.
Newbie
Miami
Sneakers
Any new news regarding this issue?
SSM 51166 2021-2022 Bronco - Headlamps Turn On By Themselves When Vehicle Is Off - DTC B1533
Some 2021-2022 Bronco vehicles may exhibit a condition of intermittent headlamp operation while the vehicle is OFF and have diagnostic trouble code (DTC) B1533 stored in the body control module (BCM). This may be due to the internal logic within the headlamp switch. To correct this condition, replace the headlamp switch (service base PN: 11654). Refer Workshop Manual, Section 417-01.
FerkinBlonco
AK
2008 KLR 650, 2022 Bronco Base (2dr/7mt/CO)
Do you know if Ford is considering taking action beyond TSB 22-2371 for the manual transmission grinding noise? Sounds like some folks were getting repeat issues after that work was performed. Can link you to the relevant threads if you're not already tuned in. Thank ya!
gonyr
NY
Is there a way to force sync software updates? Mine is on powerup 1.6 and hasnā€™t updated since last April. Both automatic and scheduled updates are turned on and nothing ever happens.
FORD EMPLOYED 22OBX
JAKE
MADISON,OH
2022 FORD BRONCO 22 FORD F150
Yes go to your local dealer shop and tell them to update your sync. They should keep the latest software version on a usb drive. This should be done at no cost if youā€™re under 3 years and 36,000 miles!
JimmyG
Greg
Fords and Cadillacs
You missed this one
SPITmadFIRE
CA
ā€”
widnere12
Georgia
Any TSBā€™s for the Raptor shifting hard AF in sport mode??
widnere12
Georgia
Haelous
US
2016 Mustang GT, 2023 Bronco Wildtrak
Posting this thread to be helpful for any warranty issues. I work at a ford dealer in north east Ohio, drive a bronco myself and have access to all TSB (technical service bulletins), Recalls, and portal messages. As well as the issues I see on the daily! feel free to conversate.
I saw this someone ask this in another thread so I'm curious.
Is use of the Ford Performance tune covered under the Ford Protect extended warranty?
Dral97
Ford Bronco, Wrangler YJ and 392, BMW 4 series
Developed a month or so after receiving
Mineā€™s at my dealer for some modem/TCU issue. I mentioned the same steering wheel issue. They replaced it without any problems.
Status
