Coming soon…. Kicker Key 200.4 mounting plate from Mountains2Metal
Copperhorse73
Copperhorse73
Justin
Mooresville, NC
2022 4 door Wildtrak
Am I the only one that mounted it to the plate underneath the steering column or something?
I had no idea that was a thing. I saw numerous threads and videos and every one I saw put it in the same place
HotdogThud
mk6 gti, '21 MoarDoor
The plate is already made of pretty heavy gauge steel, so it's a mild heat sink which is nice. And it's super easy to get to things if you need to change settings on it afterwards.
Aztec1382
Sam
F350
That’s best put in the passenger rear wheel well and there is already a company that makes an amp mount for that spot
who makes the mount
thanks
Nevermind
Dmorty217
Derek
Venice FL
Camery
who makes the mount
thanks
Nevermind
They also make a $400 sub box if you want to splurge on that too. Couldn’t bring myself to do it
Ig_bronco
Matthew
Pittsburgh PA
2014 JKU
After watching everyone get creative with mounting the Kicker Key 200.4 up above the glovebox, it seemed like a need to be filled. Thanks to my friends at @Mountains2Metal , it is becoming a reality. Thanks for letting me be the Guinea pig guys, install video coming soon.
Hard pass. I'll just grab some 1/8-3/4 plastic sheeting and make that for a fraction of the price.
Pugsly
Clayton, DE
2014 Ford Fusion
Nope mine is on the plate under the steering column. It’s almost like it was made for it.
Copperhorse73
Copperhorse73
Justin
Mooresville, NC
This is good info as I need a place to mount a gmrs base station. thats first place I’m gonna try
Bronco-ocnorB
Luke
DFW
Ford Flex
Hotdog, can you share a picture of your mounting location and how you ran the wires? Sounds a little less invasive.
Thanks!
BroncMe
PA
BMWs
like the effort, looks solid, will be on the lookout. I too have the 200.4/harness ordered and coming in 2 weeks or so, Bronco is sitting in production, hopefully in the home stretch
I don't trust my hatchet jobs, prefer a tested solution
jh3113
Jake
Phoenix
Subaru Outback
Looks promising for the right price. Less than $40. Otherwise my zip ties work just fine until I can drill some holes
DefNotBuddyLee
Austin
Mustang / Jeep / F150
Gotcha ( I know you said glove box, just double checking). The spacing just looks very similar to placement of mounting screws for the steering column plate that a number of people also used (pic credit to @philjmatt ). @Bronco-ocnorB this is a rough shot of the plate once you remove the plastic trim underneath the steering column.
Routing of the wiring is the same as going to glove box, just in the same gap underneath the stereo on the drivers side. Some zip tied to the plate, but it was super easy to just drill some holes for screws to attach the amp to the plate, or you could use some self tapping screws.
