Configuration: Aux Switches and Accessory Rail
MTDOC
Bradley
Montana
2017 f150
For me main needs are rear view lighting and additional cargo lighting, so I don't need many switches.
On the lower trim models not all the dash switches are utilized. I have been wondering if it will be posible to buy the additional switches and trim and utilize them for accessories?
Advertisement
Used2jeep
Massachuvian
2007 Crown Vic P71
I plan to run them to the parking/blinker circuit for each side so they act as blinkers and hazards.
That sounds cool. How many are you going to do per side?
colintrax
Georgia
Chevy Colorado, Ford Explorer
Forgive me if this is a rookie question, but would it make sense to run air compressor power to one of these switches?
Id run a relay to power the compressor anytime the ignition is in the on position. Being the bronco is push button and I haven't seen any of the wiring, idk how I'd go about that yet.
But yes you could use the switches.
BroncoKong Jr.
Not a Bronco ... yet
I am pretty certain you can’t run a winch from the auxiliary switches
You can use one as a kill switch with a power interrupt
Yep, you can wire the relay trigger to an aux switch
1) Disco ball
2) Black light
3) Toaster
4) Megaphone for preaching
5) Lowrider hydraulics
6) Electronic cupholder deployment
LSU Jonno
Huntsville, AL
Nissan Altima
What's everyone planning to do with their switches? I can't think of how to utilize 6. Winch, fog lights, ditch lights, driving lights. That leaves 2 more.
On a similar note, anyone have plans for the accessory rail besides a GoPro? Gps? CB radio? Do we know how many power ports are on the top of the dash?
A lot of folks get cellphone/tablet mounts from 67 designs that can hold your device in view while keeping your eyes on the road. Given the USB ports on the dash you can hook up a wireless charger to that device holder and easily pop your device in and out. That's what I'll be doing with my rail.
Bronc-OH
New York
Jeep XK, Jeep WJ
I was thinking 3 on each side if they are bright enough. Front and rear bumper then one in the center, per side. If I stick with the 2 door. Just trying to figure out if the bronco has a multi circuit like that. If not I could wire a switchback circuit on each side. Blinking circuit takes priority over the "on" circuit of the parking lights.
JonChicago
Jon
Chicago
Subaru
Is there any info on amp load these can handle? Do they run through a relay or is that something you need to provide?
Also, I'll be running an onboard air compressor through one of the switches.
Buckin Bronco
Canada
2004 Nissan Xterra
1 - Bumper mounted spots
2 - Mirror mounted spots
3 - Rock lights
4 - Light bar
5 - Rear floods
6 - Onboard Air
JuicyJ
Joe
Pennsylvania
Ram
I am 100 percent on board with hooking up a horse sound horn for one of these but how creative can you get... I am getting the badlands with the high pack. Only thing I would want from the lux is the wireless charging pad and for me that isn’t worth the upgrade. Would it be possible to take a wireless pad, mount it somewhere and wire it to one of the aux switches? Thanks in advance for any feedback.
Advertisement
Advertisement
