- Feb 21, 2020
- 112
- 7,301
- 25,622
- North Texas
- SUV
- Undecided
Maybe if you use two, or risk a multi thousand dollar top to save a few bucks.Looks like 125lbs.
That price is a two pack. It just really think it doesn’t take a $200 thing to lift a top.Maybe if you use two, or risk a multi thousand dollar top to save a few bucks.
Whatever works for you, I just find sometimes people loose sight of paying for a $40K-$60K Bronco and then cheap out on a few hundred dollars of protection.That price is a two pack. It just really think it doesn’t take a $200 thing to lift a top.
I'm curious about this. A mount would obviously have to be fabricated to be the proper height and securely hold it while appropriately disturbing the weight. But the hoist could clearly do it and is in a configuration that lends itself to adding on a mount. I guess I was a little surprised at the naysayers. If you could snap a photo, I would love to see it.I don't have pictures to post, but can probably get some later this week. I fabricated a mount that slide onto the top arm of a Harbor Freight lift for my father in law many years ago to help in removing his camper shell. He uses the shell during the winter and then takes it off during RV season. I designed the lift to slide under the back window and then we had 4 posts that we raised into the high position with some rubber cushions mounted on top that would rest against the camper shell. Then we would use the jack to lift the shell off the truck and drive the truck out from under the lift. We had straps that allowed us to anchor the camper shell to the lift for rolling around and my father in law stored it in the garage on the lift itself with a 4x4 under the top tube to prevent it from lowering during storage. He used it for 15 years until he bought a new 2019 and didn't want to spend the money on a new camper shell. The mount just slides on and off the top tube and uses a bolt through the top tube just like the original hook did to secure it. Nothing fancy, but it worked really well and I have considered giving it a try on my Bronco, but that will have to wait until spring right now.
This particular mod looks pretty rough to me. Not something I would do. But, I do admire the ingenuity to find something that works and I just wanted to post the photo to show that it can be done. BTW, this fellow used a drywall hoist, the engine hoist looks more suited for the job to me.That'd leave indentations in your soundproofing in the top. Depends on what you can live with
I need to see the top in person, but I'll probably do what i did last time and suspend it from ceiling with chains to wood boards underneath.
I like wood boards because then there's is no flex as you do with just straps. The more you can make it so it's as if it is sitting on the ground(or still on bronco) the better
Then i just park in garage with my hood under the top
A lot will depend on your space and abilities.
But if you cant reinvent the wheel, and i don't think you should, just get the harkin and call it a day
It will help some and is similar to how I stores my Jeep top, however, the OP is looking for a free standing solutions and doesn't want anything hanging from the rafters.Hope this helps.
While this may work on your FSB, how would this work with the forward 2x4 brace and the roll bar? The rear 2x4 brace could be positioned (precariously) outside of the rollbar.The engine hoists / cherry pickers aren't going to work. I have two of them for pulling engines etc and have even used them to remove the body of a full size Bronco from the frame by myself. The booms on most engine hoists will not extend enough to remove a hard top from a Bronco. IF it did, the problem would be the angle the top would come off at - tilting etc.
I've helped setup electric hoist setups for hard tops and other things and they are easy to use - and I understand people talking about trying to save hundreds on an $40K+ vehicle - but I restored a '95 Bronco (my adult son daily drives it) and I spent maybe 30 minutes building the following setup to both remove / store and reinstall the hardtop on the Bronco.
Keep in mind the hard top for the 95 Bronco is wider, longer and @ 160lbs or so. The rear cap for the new Bronco is @ 80lbs.
I'll post pictures - but a description might help, as it's actually REALLY easy to both remove / reinstall the larger Bronco top with this setup by myself and takes only a few minutes.
To remove - Take the two 2x4's into the interior of the Bronco through the rear. Unbolt the top then lift the front end of the top and slide the board between the body and the top. Then repeat for the rear. Crawl out, hook the straps to the u bolts, ratchet up one side a few inches, repeat on the other side, then simply drive out from under the top.
As for stability - I stored that top in my garage for almost a year while I was restoring the Bronco. I parked my '19 Mustang GT under it every day - zero issues.
Hope this helps.
