Gangstead
Gangstead
'21 BD 4DR 7MT Soft
Great. Thanks for posting. I ordered the same Curt hitch for my Bronco, which is same color and trim as yours, about three weeks ago. Hasn’t shipped yet. How long ago did you order yours?
Ordered 8/21 shipped 9/13.
Gangstead
Gangstead
'21 BD 4DR 7MT Soft
Nice. Mine finally shipped today after almost three weeks. Now about the wiring...🤔
Seriously. The wiring is a hot mess. I would have ordered the factory tow package but I didn't want to delay my Bronco. I think my lack of options was the only reason I was the second delivery for my dealer despite being their 103rd order.
RD32
Bend
2021 Bronco 1st Edition
Got the Curt Hitch delivered yesterday. Ordered through RealTruck.com link found here on the forum for $111 ($120 including tax).
Someone on the forum had asked if it came with the mounting bolts, it does.
Not a lot of clearance so you have to get the nut on before pushing the bolt all the way in. Can barely get your fingers in there, but it's possible with a 3/4" wrench. HD Modular bumper pictured.
It's barely a 1 beer job at 15 minutes. Hardest part is getting 110 ft-lbs toque lying down on your back and reaching up. I'm happy. Definitely a good deal compared to $350 for the OEM Ford one.
Update:
Profile pics for anyone who is concerned about clearance and departure angles. It doesn't stick out any further than the bumper and the recovery loop thing is still the lowest thing hanging.
I
Perfect. I'll be sure to stretch my install to 3 beers.
No wiring harness?? Installed the Ford OEM one this week and it was literally 4 bolts. What takes all the time is the wiring. Plan half a day for that.
Lakelife36
Ben
Interior of BC
That's news to me. I'd always heard Class II = 1.25" and Class III = 2"
Curt's website has just left me even more confused. https://www.curtmfg.com/types-trailer-hitches#HitchClasses
They say:
Class II = 1.25" and up to 3500 lb capacity and 350 lb tongue weight.
Class III = 2" and up to 8000 lb capacity and 800 lb tongue weight.
Then the Curt hitch for the Bronco says it's class III ... with a capacity of 3500 lb and 350 lb tongue weight so it's class III opening, class II rating according to their own documents. So I don't know what's what any more.
Edit to add that the towing capacity of the Bronco is up to 3500 lbs (depending model) which is the class II range.
I think they call it a Class III because they give it a higher rating with a WDH, which they won't do with Class II recievers.
Parker
PA / CA /AZ
Gr Che Overland, Corvette, Tahoe, 46 Chevy 2ton
Curt makes great stuff. Their front receivers are typically the cheapest front end/radiator protection you can get.
mC.242
2021 Big Bend 4dr (sold)
I'm probably going to bite the bullet and buy a factory wiring harness and have the dealer install it. Likely going to cost me $300-400 but still less than the factory tow package and no delay.
Mr. Nice
Jayson
Minnesota
12' Boss302, 08' Audi TT, 13' CRV, 14" Ridgeline
Sorry no seven pin option after the fact.
Jdm89
Hot Springs, Ar
2010 F150
You are in for some major disappointment if your looking for simple wiring...
I never said anything about "simple" I just only need to go the 4 pin route vs 7. Ill never tow anything heavy enough to need trailer brakes. Thats what my f150 is for.
Jdm89
Hot Springs, Ar
2010 F150
The wiring harness is not the problem. It's the labor to run the wiring thru the interior thats the issue. Well documented. Much easier and less intrusive and probably cheaper to order factory hitch.
Thats if you have the option to get the hitch. On my base 2 door sasquatch the tow package was not available.
Lilj4425
Jacob
Greenville, SC
2021 Badlands Bronco
Still am baffled as to why Ford doesn’t offer a 7 pin option as an accessory.
mC.242
lakesinai
Charleston SC
That is still only a class 2 correct?
Its complicated! The problem is that the towing capacity is in class 2 range (<3500#), with regard to its trailer tow capacity. Some Broncos are rated less than 3500#! Usually, cars that tow less than 3500 lbs have the 1.25" receiver, to prevent users from towing too much. There are cars limited to 1,000 or 2,000 lbs. But the Bronco has a 2" receiver which makes it a class three receiver, even though the car is not rated to tow over 3500#, and so is on class 2 territory.
Early specs on the bronco called it a class 2, but since most people have receiver bars for the 2" hitches, they probably moved up the size of the bar, while keeping tow capacity right at the class ii/iii boundry.
Generally, a class iii/v, 2" hitch receiver is part of a bar assembly that connects across to both rear frame members, giving it strength. In fact, the lack of a cross member, or 2 cross members, effects the weight capacity of the receiver itself, which is ideally welded to the cross members, which are bolted to the frame. Hopefully, the aftermarket receiver bolts to existing cross frame members. Whether, as a bolt-on, it has the same tongue weight and tow capacity as the OEM unit, we can hope.
https://www.curtmfg.com/types-trailer-hitches#:~:text=Class 2 vs Class 3,go up to 3,500 lbs.&text=On the other hand, class,gross trailer weight.
The strength of the receiver is not only important for bearing the weight of a trailer tongue, but also for handling the torque loads from modern bike racks, like my KUAT, a heavy platform rack that holds two heavy mountain bikes over some bouncy roads.
I wish i had my Bronco so that i could see the difference between the OEM bike rack and the aftermarket one! One member did a tow test here with his OEM hitch, and was quite pleased.
Finally, the wiring for an aftermarket hitch installation can be expensive as well, although that may not matter if its for a bike rack. However, eventually, someone will see that hitch and want to tow a little trailer to the Hardware Store, and then . . . Whats more, KUATs newest rack has tail & marker lights that are on the rack, helping protect the rack from cars running into it. So the rack needs a trailer connection.
lakesinai
Charleston SC
7 pins are for electric brakes, not normally used on single axle trailers under 3500#
lakesinai
Charleston SC
Ford Bronco Curt Hitch (Class III) Installed on 2021 Bronco Black Diamond 4-Door ABB57053-D315-4B2D-BC8F-CC0A24E2844C
You do nice work. What frame members did the Kurt receiver bolt to? Do they look sufficiently connected to provide good support? Id love to hear how the wiring went as well!
