CV grease
V1Rotate
Brevard, NC
2022 Wildtrak
Had a drivers side CV boot slinging grease due to a poor job by me making sure the clamp was seated correctly. Can anybody tell me the motorcraft part number for whatever grease Ford uses in the half shafts these days?
Ducati1098
2022 Bronco Wildtrak, 2012 Ford Fusion
I wasn’t able to find a Motorcraft number that matches, but here is the grease Ford supplies when you purchase a boot repair kit. I don’t think they sell it separately.
Ford Bronco CV grease IMG_1179
V1Rotate
V1Rotate
Brevard, NC
2022 Wildtrak
Thanks!
Felix808
SRV CA
That is interesting. I'm use to the black molly grease, but what is the yellow grease packet?
Ducati1098
Inner and outer joints are different and require different grease.
Felix808
SRV CA
Thought maybe. Still don't understand it as I've not seen 2 different grease packs before. Proving again what you know is all you know :unsure: . My guess is the outer gets the black molly grease???
Thanks again 🤠
Ducati1098
Thanks again 🤠
Correct. The black on the outside and the yellow for the inside. From what I remember the inner has some small needle bearings which is why it requires a different type that works better for them.
V1Rotate
V1Rotate
Brevard, NC
2022 Wildtrak
You sure that isn’t backwards? The grease inside my inner boot is definitely dark gray from the factory
Ducati1098
Could be very possible I have it backwards.
Bad To The Stone
Bud
2023 Badlands;2015 Hellcat;2016 F150
Do you have the part number for this boot repair kit? Doing the BajaKits pre runner and adding their extended axle. Was going to put new boots on at the same time and Ford says I can only gets boots on a whole new axle, no separate boot kit? Thanks!
Bad To The Stone
Bud
I have been repacking with Moly, your not going to buy more life with any other grease.
Got it sounds good. What about Boots and clamps, just using aftermarket based on size? I can't find anyone who can look one up for the Bronco?
Ducati1098
Can't get the boots or grease separately from Ford for badlands or sasquatch package according to the catalog.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
I have spares from @NORCALGXP if your over 50K miles I would buy new CVS.
