Damage while using winch on improperly installed Rough Country High Mount
Status
Not open for further replies.
Deleted User 5719102
Who's
On a Lake
22 2dr
That's the downside of all this "prebuilt" stuff. You buy the baddest Bronco trim, slap a bunch of bolt-ons on it, assume the engineering has been done, and you go out and play. Back in the day you knew you had weak factory junk and it would need some fabbing to hold up.
Well back in the day we never bought aftermarket bumpers either. We would take off the stock bumper, extend the frame horns outward. Mount the winch plate on, then made the bumper around the winch. Sometimes it came out looking cool, sometimes not, after a few beers everything looked awesome. Either way it took a beating and kept wanting more. LOL!!
Who iz
Otis
End of the Oregon trail
F250, 4Runner, Jimmy
**********EDIT*********
100% 'Tricky' resolution....now time to buy, buy, buy more parts? (y)
Solve this issue....and sell,sell sell! :unsure:
MPTB
Pat
Wisconsin
Man I really dig how easy this setup is to take off when not needed but i can see how the high offset would act as a lever. I'm surprised this is the first time anyones had this issue. Has anyone else installed the rc high mount and actually put it to real use?
Tricky Dick
Dick
PNW
www.TD-Distributing.com
It's not even that easy though, I consider it permanent.
techdisaster
Not a Bronco
My LOD brackets finally shipped and will be here this week. I’m installing them with the same RC high mount winch. LOD are 2-3 weeks behind orders right now.
Because I cancelled my trip to Moab, I don’t need my brackets any time soon. @tricky dick I can send you my brackets so you can install them by Bronco Safari. Then send me your set when LOD gets them done.
Just take lots of pics of the install so I’ll know what I’m doing when I get mine.;)
MPTB
Pat
Wisconsin
With leaving the plastic covers off, plow hookups on the cables, using a guide stud on either side and having something to lift it with its not so bad. I just disable the park sensors and have no led light.
It's concerning that you had this happen without even working it that hard. If you were nose down pulling up do you think it could have bent the winch back into the grille?
Tricky Dick
Dick
PNW
I got mine through a reseller so they might ship faster? Depends on who actually hold the inventory. Thanks for the offer, I think I better take you up on it. PM me?
I don't think so, the leverage wants to rotate it forward/down.
techdisaster
Not a Bronco
PM sent.
RubyRedGT
Greg
Pittsboro, NC
21 Bronco. Sold the 1968 and 2015 mustang GTs
Thanks TD and others for this info. Looking forward to updates. I recently installed a winch with the RC high mount but haven’t put it to much use yet.
Ford Bronco Damage while using winch on improperly installed Rough Country High Mount A68964C2-2FAB-4CEA-BD89-3EF7787F0CA8
Tricky Dick
Dick
PNW
It's a shame, I do really like it otherwise, it's my favorite looking bolt on mount. I've seen them hold up fine to lighter pulls but we should be able to max out these 10-12k winches without worry. To be fair to RC, the mount itself seems to have held together fine, but they should have seen this kind of thing in prototype testing and included a frame reinforcement solution.
techdisaster
Not a Bronco
What prerunner bar is that? I want to do the same but I wasn’t sure about fitment. Do you have a side picture?
Bikeric
Tulsa
2022 Badlands LUX on 37's
When I removed my Capable bumper and installed the Havoc front winch bumper I was shocked at how flimsy the Ford sheet metal bracket was. The Havoc bumper came with 1/4” thick brackets that sit behind the ears and bolt together both through the frame and the ears to the bumper. It was certainly confidence inspiring for me. Those Havoc brackets would work for any other bumper that uses the 6/8 factory location holes. I’ll check tomorrow to see if they’ll maybe sell a set?
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
I'm doing exactly the same. I like the RC mount because it puts the winch high and tight to the grill but I was surprised to see they don't include frame stiffeners considering how high above the frame center line it mounts. Not optional (*see exceptions)
*Exceptions: mall crawling
Just here to quote myself from a couple weeks ago 😄
Tex
Cliff
San Angelo
Wow, that sucks man. I kinda wondered how well those winch mounts fared on the trails but figured they were fine because I hadn't heard anything negative about them so far.
Even though it was a real pain in the ass to install and not the most accessible, the RC hidden winch sure as hell isn't going anywhere...it ties into the recovery points as well as the front crossmember, while the fairlead is separate of the winch and tied into the recovery points and front bumper...so there's very little off-axis bending moment translated to the winch.
Bikeric
Tulsa
The black steel stamping with nuts welded on is the only thing that was behind my Capable bumper. I assume the Modular mounts the same way.
You need similar parts to 7,8,10,11 seen on the Havoc bumper installation guide.
Ford Bronco Damage while using winch on improperly installed Rough Country High Mount BFE8376E-587A-4C63-91D7-8B7B3C883336
Ford Bronco Damage while using winch on improperly installed Rough Country High Mount 690257E2-9423-4169-8BA6-0ABA6EF7B355
Status
