Dash Accessory / Picatinny rail news?
VelocityBronco
E
Exact same place. It would just sit elevated above it.
THAT'S the rail I want! This looks clean, and you can still mount picatinny accessories to it, by the looks of it anyway.
I don't care for the picatinny rail version, as I don't care for picatinny rails on my weapons, just have them where needed...
AzScorpion
2019 Ford Ranger SuperCrew Lariat 4x4
I can see aftermarket making these M-Lok instead of the Pic rails. Plus there's already adaptors from M-lok-Pic so this should be quick and easy to get out there for aftermarket.
Hoofnmouth
mark
N ca
ford focus st
I posted this before,its a strip of pictinny rail i had left over from a project i plan on usung it if i can pretty inexpensive .
Ford Bronco Dash Accessory / Picatinny rail news? 20201122_155734
az_dirt
Jay
21 Bad Sas AMB
So...
Was curious if this is accessory rail is still a thing.
OBXA51
Canada
2019 F-150
So...
First thing I thought of when I took possession of mine. I was positive the rail would come standard, as I remember it being hyped.
Michael Grasso
Indianapolis
So...
Ford gave the project to 4WP who is now in the process of making them. They estimate around the 6 month mark.
Mg
LeBronco
'19 Expedition Platinum
is this a confirmed piece?
JaxGtc
It will be aftermarket and nobody has seen any semblance of an accessory rail yet. To be honest, I don't think you would want much on the dash. I used a gopro on my Austin adventure using the single mount point and right then I realized much more would have not been good for visibility. I think the benefit of the rail is it would let you choose an ideal placement along the axis of the dash. Just my .02.
Bulletbill
FL
Honda
I was also wondering about this. Cool concept, which seems to be what most of the Bronco is.
ICUGAZN
Kevin
Woodbridge, Virginia
2019 Raptor
Does anyone know whey the BYOD mount bar is coming? Thanks
Ford Bronco Dash Accessory / Picatinny rail news? 1629677861634
BigFootie
Wisconsin
2013 ES-350, 2022 Badlands Sport, 2023 Heritage Ed
Here I was thinking it was going to put the Bronco over the GVWR so no longer an option.
luptanpitman
Los Angeles
'21 Bronco, ‘21 Polestar
I tried an option I got off amazon last night and it had way too much shake - the iPhone worked hard to stabilize but not good enough. I think the biggest issue is the bar that holds the bracket. If could stabilize more somehow it could work - when I braced it a bit with my hand it worked pretty well. ideas???
luptanpitman
Los Angeles
Ford Bronco Dash Accessory / Picatinny rail news? IMG_9009.JPG
I have a feeling this will be too wobbly to work as well - it will need something that doesn't have an arm that connects to the phone which is heavy enough to create shake.
