? I sent a request to the dealer Monday to make changes and dealer ignore my request. And Thursday Ford sent me email with vin and build date 10/10. Can I still make changes or am I screwed?
Not going to happen..Add sasquatch and 2.7
I added Sasquatch after my vinAdd sasquatch and 2.7
Only works for Badlands from what I've seen.I added Sasquatch after my vin
You can’t change engine because iirc that should be a vin code
I read your previous posts on the subject, and I'm curious to see if you actually get it. Good luck!I added Sasquatch after my vin
My build week was originally 9-26I read your previous posts on the subject, and I'm curious to see if you actually get it. Good luck!
Certainly! I assume your Bronco order already had the correct transfer case for the Sasquatch package? That could be a hindrance for someone else who may try to add Sasquatch after receiving a VIN....either way, I’ll take it!
Gotcha!Certainly! I assume your Bronco order already had the correct transfer case for the Sasquatch package? That could be a hindrance for someone else who may try to add Sasquatch after receiving a VIN.
