- Jim
- Aug 1, 2018
- 20
- 4,050
- 9,242
- Down south in Dixie
- 2018 Mustang GT, 2019 Wrangler, 2020 Ranger
- Outer Banks
I bow to your intelligence, or I'm amazed at your imagination. Either way Matt, you had my undivided attention.This happens when the specific barometric pressure goes below 20 CFMC. It so happens that the pitch of Ford's programmed chimes will be altered by the lower barometric pressure ever so slightly, but enough to hear the difference. This effect is influenced by the Williamson Cationic Curve, which is well known by Air Force and Navy pilots, who in WWII experienced missing instrument ques when audible warning chimes sounded different at varying altitudes . . . due to the changing barometric pressure. Therefore if your chimes sound different for a period of time, it is only because you were experiencing a temporary change in barometric pressure. If you were to use a Williamson Cationic Curve conversion chart ($20 on Amazon) and the Williamson App on your phone, you will be able to see the degree by which you need to change your barometric pressure to hear the chime in its intended tone again. In most cases you can do that by rolling up all the windows and blasting the AC on full for 5 minutes, followed by immediately changing to full heat for about a minute. The sudden change in temperature will balance the barometric pressure and the chime will sound normal again.
But it's possible this is just a bunch of malarkey I made up because I'm bored tonight.
BTW Jeff, all I have ever heard from both of my Fords is that confounded "Boo-De-Do".
