How to disable seatbelt chime
helifino16
Ron
Mount Sinai, NY (Long Island)
I couldn’t find this anywhere so I figured I’d post it. If you have a big dog riding shotgun or are driving around on your farm where a seatbelt isn’t needed and the seatbelt chime is bugging you it is easy to disable.
Ever since I had my Bronco in the shop where they did a bunch of ForScan (like) updates, I have not been able to use the procedure in the manual (Page 56, if you want to look) to disable this. THANK YOU, THANK YOU, THANK YOU for posting this alternative solution. Worked like a charm.
I'm more likely to wear the seatbelt if I don't have that chime nagging me to do so. (My choice, not enforced). Much appreciated!
JakeC
Jake
Dearborn, MI
michiganbroncos.club
2022 Badlands
Why didn’t you just have the no seat-belt charm disabled in FORSCAN when you had it in? (That’s what I did)
Edit: Maybe because it was the dealership that did it….
‘21OBX
Ken
90Bronco19
2022 bronco outer banks
This doesn’t seem to work for the raptor. Anybody know a work around yet?
Bummer forscan may be your only options then. Are you waiting for the light to come back on? It seems like forever. I wonder if the Raptor has it in a settings menu either on dash or on the touchscreen.
Tarheel_Wes
Wesley
FJ
So....just in case, how do you UNDO this (get it back to factory setting)?
Trevor
Gilbert,Az
Bronco raptor
Never saw it in the settings, I waited a long time and the light never turned off let alone come back on. Tried numerous times and failed.
XirallicBolts
Paul
Wisconsin, USA
2016 Flex EcoBoost, 2010 Milan
Same procedure will reenable the chime. I did it in my Flex for driving around jobsites
‘21OBX
Ken
90Bronco19
It seems like forever when you’re waiting on it. Maybe ford for wise to it.
thatch11b
Philly
2022 Ford Bronco 4 DR Softtop
Thanks for the info. Did it tonight.
NVCowboy
William
Henderson, NV
2002 F350. 2022 Big Bend (Sasquatch)
I’ve always equated this process to trying to say yes while shaking my head no. However, backing up to trailers or backing trailers is a bad time to have the truck screaming at me. Damnit, I know I’m not belted in! I’m in on this wheneverthehell Bronco arrives.
Done. Thank you for the process.
JetG
Jet
TX & FL
2018 Macan Turbo w/PP & 2016 911 Turbo Vert
Same issue raptor and it doesn’t work.
Twisted Optix
Matt
2023 Outer Banks Bronco
1) Sit in the seat you want to disable the chime for. (you will have to do it individually for all seatbelts you want to disable)
2) Push the ignition button with the key in the truck and without pressing the brake pedal. (So the ignition is on without the truck running)
3) Wait for the seatbelt light to go out.
4) As soon as the seatbelt light goes out buckle and unbuckle the seatbelt 3 or 4 times until the seatbelt light comes back on.
5) Buckle and unbuckle the seatbelt one last time, the seatbelt light will flash a few times letting you know you did it right.
Worked like a charm! Thanks!
Twisted Optix
Matt
It takes about 45-60 seconds for the light to turn off initially. It worked for my driver and passenger seats, but not for the back seats. Which is probably good so my kids don't sneak their belts off!:LOL:
