stm378
Sean
Maryland
Highlander
Have any other soft top owners lost the retaining clip for the top prop? 25$ to replace the
tiny piece of plastic. Pay attention when lowering the prop, it probably got spun 90° and fell out, it was just missing and nowhere to be found. Working on another solution will post if I come up with one.
Why not just get the IAG ez-lift system instead of spending all that money on a small plastic piece?
SurfsUp85
Joshua
Windsor, Ontario
youtube.com
2021 Bronco 4 door Outer Banks, Kia soul 4u
The problem I have is that the auto high beams aren't active until you reach a certain speed. It would be nice for them to work inside of a dark neighborhood driving under 25 mph.
Mine go on at any speed. They always flash on and off when I'm driving through the subdivision at night. I didn't do anything, just set it to auto and it does it.
Jawbox
Greg
Crookston, MN
Bronco 4 Door
I love mine. It's probably my favorite add on, especially with the raised lid cargo enclosure.
Havoc1
07 F250, 20 Accord Sport, 21 HD
Not sure if this has been mentioned before. But a lot these can be enabled/disabled via the APIM (touchscreen).
I have a manual BD and was playing with the settings in my radio and discovered I can have the horn feedback disabled if I want, DRL's, auto lights, auto highbeam, locks, etc.
Rlack75
Ron
Marietta GA
My keys never leave my Bronco and I dont know what this double honk yall speak of is....
Just curious, where do you live? 😂
I need a second bronco!
Rlack75
Ron
Marietta GA
This is because you are fooling the car into thinking the key is still inside because of proximity. The double honk when you have the vehicle running but leave with the key.
My hack for this is just to not close the door all the way when I need to get out with it running haha
If you forget to leave the door ajar the bronco has a feature where it will double honk to remind you that you didn’t leave the door ajar! 👍🏽
Toyhoarder
The west
Early Bronco, F-150, F-450
All these things you guys are talking about I was able to adjust in the settings. I sat in the dealer parking lot for probably 20 min playing with settings before I took off.
the missing key double honk warning you’re talking about can also be disabled in the settings
Ford Bronco Easy Bronco Settings/Hacks (I'm talking to you seatbelt chime & double honk when engine running) 9F0E3ED2-2FD7-4CA4-821E-8700A5E6302C
Headsong
Sounds like I need to go check settings again. maybe an update?
And then balance this HUGE frickin' annoyance with the occasional value of either the fob dropping to the floor when I didn't know it or actually not shutting down the vehicle when I thought I had....
Well, at the risk of calling you a liar, I'll just say no. It ain't there. That would be the one thing most of us yearn to find.
