Disabling TPMS Sensors
mpeugeot
https://www.bronco6g.com/forum/threads/tpms-adjustment.37940/
Take a look at this thread, it should help. I am pretty sure that one of these does it. I am traveling a lot and don't always have easy access to everything. For instance, my Bronco is in San Angelo, TX and I am in Corpus Christi, TX.
Doubleajaybrock
Aaron
2023 Bronco 2 Door 2.7L
Has anyone figured anything on disabling the tpms with FORScan?
mpeugeot
BAUS67
redneck
Central PA
So if you don’t have forscan or computer skills you can do what us rednecks do.
Remove TPMS from wheels.
Purchase some PVC tubing and end caps.
Place TPMS in tube and glue on end caps.
Drill a hole in one end cap and install a regular tire stem.
Inflate the tube to desired pressure.
Throw the whole shebang under the seat and never look back.
No TMPS light ever again.
Have done it for years, works like a charm.
One word of advice. If pulled over by the po-po they might think it is a pipe bomb if they search the vehicle. 😁
Doubleajaybrock
Aaron
It's easy to do, it's in the BCM module. You just need to look.
figured It out I think. So this should not set off any lights or warnings if I have wheels with standard non tpms valve stems, correct?
thanks for the help. I’m just learning the FORScan
Ford Bronco Disabling TPMS Sensors TPMS Moniter off
MillerAndCheeto
Robin
Calgary, AB
2 Door Cyber Orange Wildtrak Sasquatch
Love this!!
TeocaliMG
Plymouth Michigan
2021 Bronco Badlands non-sas 4 door manual
Have you or anyone else in this thread re-enabled TPMS after disabling? I disabled mine since I didnt have time to take my old wheelset to a shop before setting up and testing the new ones. I left it disabled for about 10 months and just did a teardown during my tire rotation to put TPMS back in and re-enable. After enabling, I got nothing... just a TPMS fault and no values for any tire. Install was easy, not sure what I could have messed up. Maybe I missed another step in forscan
Doubleajaybrock
Aaron
I turned it off for a day just to see what happened. When I checked the tpms on the dash display and in ford pass, I just had dashes with no numbers. I reactivated it and it displayed everything ok.
I was just getting prepared to do this with my new wheels and was contemplating using regular valve stems Vs tpms sensors.
Devilbrad
Brad
Pacifica, CA
2023 Bronco Wildtrack. 2017 Challenger Hellcat.
I hope this works. I just installed some 37's on my Battle Born Wheels yesterday. I had bought 5 sensors from Tire Rack that I thought were factory Ford, but they came loose in a bag. The first one I pulled through the wheel and right before it seated the brass threaded end snapped off. I ended up just putting rubber valve stems in all five wheels as I didn't want to break more sensors.
Doubleajaybrock
Aaron
Let me know for sure if it works out for you.
TeocaliMG
Plymouth Michigan
Thanks, mine came back eventually. I didnt need to go to a dealer or anything, I think just just needed some miles after reactivating the DID to wake up and start reporting correctly.
