I am building a DIY lift for the rear section of the hardtop, as I didn't like existing solutions on the market (both I found were expensive, one puts unintended forces on the mid panel latches and the other would become a brick if the app is no longer supported)
This is cheaper, but not significantly so. What's more important to me is fixing the flaws I saw with the current solutions on the market.
The plan is to lift using four universal u-clip straps tucked under the roof panel ridge. These will be tied to eachother width wise across the roof, with a hole-punched square tube in the middle. The square tube will be permanently connected to an electric hoist on the ceiling, will run cable through two eye bolts on the square tube. The hoist will be used in pulley config to reduce the speed and increase the weight capacity
I chose to use the clips under the roof as this puts no force on any of the gaskets, a concern I had with some of the other options on the market.
Part list so far:
Pipe insulation for the square tubing - 50mm diameter matches outside perimeter. Https://a.co/d/3zmDFtC
roof straps (also allows you to in fasten to roof without roof rack) https://a.co/d/eowxHLH
Electric hoist: https://a.co/d/6LxgYvb
caps for square tube:
https://a.aliexpress.com/_mrtaHVm
Square tube: https://www.lowes.ca/product/round-...nc-plated-steel-perforated-square-tube-103637
Part list so far:
