DIY wireless electric hoist
xdvgx
Ottawa
Bronco Black Diamond
I am building a DIY lift for the rear section of the hardtop, as I didn't like existing solutions on the market (both I found were expensive, one puts unintended forces on the mid panel latches and the other would become a brick if the app is no longer supported)
This is cheaper, but not significantly so. What's more important to me is fixing the flaws I saw with the current solutions on the market.
The plan is to lift using four universal u-clip straps tucked under the roof panel ridge. These will be tied to eachother width wise across the roof, with a hole-punched square tube in the middle. The square tube will be permanently connected to an electric hoist on the ceiling, will run cable through two eye bolts on the square tube. The hoist will be used in pulley config to reduce the speed and increase the weight capacity
I chose to use the clips under the roof as this puts no force on any of the gaskets, a concern I had with some of the other options on the market.
Part list so far:
Pipe insulation for the square tubing - 50mm diameter matches outside perimeter. Https://a.co/d/3zmDFtC
roof straps (also allows you to in fasten to roof without roof rack) https://a.co/d/eowxHLH
Electric hoist: https://a.co/d/6LxgYvb
caps for square tube:
https://a.aliexpress.com/_mrtaHVm
Square tube: https://www.lowes.ca/product/round-...nc-plated-steel-perforated-square-tube-103637
Ford Bronco DIY wireless electric hoist PXL_20220922_214409815
xdvgx
Ottawa
Any tips or prior experience will be appreciated, I will update thread as I make progress
adamruiz2001
SoCal
Ford SVT Lightning
Seems like a pretty solid idea! Will keep an eye out for progress pics 🍻
Mikey D
Ormond Beach, FL
www.mikedelninno.com
2005 Ford Explorer
I'm thinking something similar. Keep us posted.
dcox90
Devin
Georgia
Part list so far:
Any update on how this worked out? Particularly interested in how those hooks worked.
xdvgx
Ottawa
Probably won't be working on this until next spring as I don't want to go topless in the winter. I can tell the hooks are very secure, my only worry is them sliding around. The strap will need to be quite tight and the middle of strap should have something to lock it's position along the tube
Johnny Mo
Westchester County, NY
teachu2shoot.com
I was planning on using strut bar U channels to make a rack - pool noodles or pipe insulation as padding and then tow straps to lift - with a Pittspurgh Hoist in the ceiling. But I'm intrigued and following.
GreyZ
Gulf South Louisiana
Is the roof designed to be lifted from that lip like that?
Mikey D
Ormond Beach, FL
2005 Ford Explorer
BRONCO TOP HOIST | FORD BRONCO MIC HOIST A TOP POWER HARDTOP REMOVAL S – Lange Originals
Check out the lift from Lange. and I quote,
" Hoist-A-Top Hardtop Lifting Brackets literally do all the lifting! Lifting Brackets slip in easily and lift from the reinforced rack slot on your Bronco Hardtop. Rubber coating protects your top. Closing your rear window when you lift, saves valuable room on your ceiling."
xdvgx
Ottawa
The roof weighs 70 lbs, the force on each corner is very small. I'm sure there is more lifting force from a kayak or luggage shell on the oe roof rack
Fly
MA
Subaru Outback
Any updates using those straps/hooks? Any trouble with them sliding around or pulling out when lifting?
xdvgx
Ottawa
Unfortunately not, I tried to install last year but couldn't find a roofing member behind the drywall strapping on my garage ceiling. I'm going to take another crack at it this year with the hoist in a static location instead of a trolley, though I'm not sure if I will stick with the hook idea
