Do large 32, 33, 35-inch tires avail on higher trims handle city potholes beautifully?
motown313
metro Detroit
Cadillac XT4
I am in metro Detroit and I'm eying that Sasquatch package (35-inch tires, etc.) partly because the potholes here are soooooo bad (worst in the US). I assume, yes, such big tires handle potholes like butter? I also assume the trade-off of not feeling potholes is going to be louder at highway speeds? Thank you!!
NCOBX
H2 Hummer, Holden Commodore
Largely dependent on the suspension design not as much tires. Being the Broncos tow rating is so low I imagine it’s safe to assume the suspension should be very forgiving.
Not all large tires are noisy, I run 37 KO2s and they’re fairly quiet.
Blksn955.o
Greg
Wentzville, MO
Might want to watch the sidewall still. Take them at baja speed will probably not be the best idea...fun to watch I bet.
Silver-Bolt
Portland, OR & Eureka, MT
2018 Ford Raptor, 2020 Audi SQ5, 2023 Wildtrak
Stay with 17" wheels so you have the maximum amount of sidewall height. A 35" tire on a 17" wheel will ride way better than a 35" tire on a 20"-22" wheel.
HoosierDaddy
I don't know about that....define "largely".
I'd argue, regarding potholes, it's far easier to counter them with a taller side wall than suspension tuning. Up here in Chicago-land I have seen potholes actually destroy rims, physically knocking a HUGE chunk of aluminum out of it, -not mine- probably the worst pothole I have ever seen, on curve, on a highway, so it was in a blind ....cars were lined up at the side of the road with bent and broken rims. I swear, that one car was missing about 1/5 to 1/4 of the aluminum rim.
I have an Outback and a Legacy right now, both have shitty soft suspensions, very similar vehicles, most parts interchange. The Legacy is low profile tire (factory size) the Outback is (stock) like a 29"/30" tire , I'll take the larger sidewall/taller tire of the Outback every day and twice on Sunday.
The difference is night and day on freeze joints, buckled pavement and potholes, of course.
My Sentra and Legacy both had lower profile factory "car" sized tires.... they both had suffered bent rims- repeatedly. The Outback's taller small truck tire absolutely absorbs the potholes FAR better. Never a bent rim yet....
On the opposite end is my GM 1 ton standard cab pick-up, 1985 ...built when trucks were "tough", a time when men were men and sheep were scared, those springs are so stiff....those washboard freeze joints roads will rattle your fillings out, but even on 33"s, the tire just doesn't fall into the potholes nearly as much. To soften the ride, I lower the tire pressure from full load rating (80psi) to about 50, make that E rated sidewall flex. Did the same with my 01 F250 diesel. Aired up when I had a load...
So yeah, OP, a soft suspensioned Bronco riding on soft sided 35's will be like riding on a marshmallow.... :cool:
Rivers90
Ben
california
xterra mx5
My brother had a car with low profile tires and before long he had multiple bent or dented rims. Now he has a suv with big aftermarket tires and he has been tire problem free. He drives the same roads.
I think the post saying tall side walls keeps the rims safe is true.
