Do you think MT Badlands will end up being late availability?
mrcx
Grapevine, TX
'67 Camaro
We all know that MT + Sasquatch is going to be late availability. Right now I am looking at getting a MT Badlands without the Sasquatch package. This seems to get me everything the Sasquatch package has, minus the wheels/tires and maybe a 10mm bump stop.
If my assumption is accurate, it stands to reason that a MT Badlands would also need to be late availability. Otherwise there is no reason they couldn't put those same components together on other trims. Unless they are just trying to discourage sales of Base\MT\Sasquatch. Which if it wasn't late availability is what I would be getting.
If the MT is going to be late availability, then I will just go with the ManBaseSquatch since I'll have to wait either way.
Broncocito
B
NM
2021 Tacoma TRD PRO Manual
This makes perfect sense.
cp6789
Providence, RI
2018 Jeep Wrangler MOAB
Could be. I am in the same boat of MT Badlands. What is getting my hopes up for on time release is both the Overland 4 door concept and 2 door Trail Rig are both Badlands with MT. That being said, the 2 door has the modular hard top which is late availability so who knows.
wolfpackinva
Santiago
Doswell, VA
'17 Focus, '08 E350, '13 Tundra
They are already rolling around with Badlands with MT. I would suspect it has to do with engineering the right gearing or speed calibration. Or that Ford just doesn't want to sell MT with Sas.
blue182
Tom
dmv
AMB BD
They’re probably not allowing the mid package with the manual on the Big Bend and Black Diamond to make sure they’ll have enough manual transmissions for the Badlands. They just don’t want to say that. They won’t have enough manual transmission at launch. They’re prioritizing the Badlands at launch.
Blksn955.o
Greg
Wentzville, MO
17 Ford Escape Ti, 94 Ford Mustang GT, 21 BL
The manual BL was something noted from the get go. I think the supply chain limits are at the take rate level in addition too the BL. Ford probably negotiated x volume and was set for y capacity and the manual sasq would change those and more than likely result in a higher take rate.
Manufacturers of these components will need ramp up time and with covid that adds another level of complexity. So my bet is they are saying late avail as a quasi my22 as word play.
BL at the higher price point and that trim as close to but not Sasq along with the mid and up only avail in manual will help keep that trim possible. Now if no one waits for mansquatch...yes it will be delayed IMHO.
BenBronco
Alabama
2011 F-150 and 2020 F-150
My build is a BL with MT and I have the same question/concern. Only hope is that Ford always planned BL with MT option and never indicated late availability even when they called out late ManSquatch.
Rogues Gambit
Eatontown, NJ
'19 Ram Rebel, '07 A4 Quattro
Doesn't matter too much to me, gives me more time to stockpile parts and have a yuger downpayment
Hopefully they're not too late though
Drex
Jake
Makes sense. It sounds like the MT and Sasquatch is going to be ordered a lot more than Ford anticipated, which means their suppliers bid and planned on making a lower number. Could be delays in all MT applications and possibly Sasquatch builds in general. Mansquatch would be the intersection of both of those possible delays. So I would think that is worst case. Short version is I think there will be a bunch of MT vehicles, favoring the higher profit BL's) released and then a long pause while they get more stock from their suppliers, but I don't think a delay in MT (even the Badlands) will be related to the late availability of the mansquatch.
TrailDust
Adam
Nebraska
23 Bronco, 23 Bronco Sport, 97 F-150, 07 Cummins
Since the BL is the highest end model that can have a manual, and liekey their money maker too, this makes sense. Probably build as many BL as they can with the manual that doesn't exhaust other commodoties, then start builds of lower end models that want the manual. I'd think you should be ok getting a BL with manual early on, other models will likely be different.
BadSquatch21
PA
Land Rover and Porsches; '22 Mansquatch
I've said from the start I think the delay in the manual Sasquatch is 100% marketing to extend and delay the demand of Broncos. They know people will wait for them so Ford gets to stretch production out and keep the demand flowing. Same reason for the white tops.
