If you turn the stereo way up, you just notice how bad the stereo is.If you turn your stereo way up, you can't really notice the sound.
I got a box and sub installed on the tailgate door last week. My husband said the name of the sub is appropriate, BLAM!Ditto, LOL! Her brother finally got the hang of it, but our daughter does the same thingā¦ SLAM!
I used SoundSkins in my F-150. They only cover the inner panel of the door and the pre-cut holes still require a good bit of cutting because they're only stamped and none were separated in the panels I used. I wasn't overly impressed. The outer portion of the door needs the sound deadening with an MLV product as previously mentioned.Just saw Crutchfield has a solution from Soundskins for the Bronco. Might just go with that option.
Apparently they flipped the switch so you pull down from the top instead of from the bottom.Iām curious, too. Whatās different?
No it doesn't, and no its not.I was thinking the other day when I got out of the broncoā¦.ā Dang, the door sounds like a truck when it closesā¦ā. Oh yeah. It is one.
They didn't move it, just changed how it operated. 2021 you pull up; 2023 you pull down. At least on BL and WT. Just don't know why change it...That is interesting, where did they move it on the '23?
I guess it would have been impossible to just put a foot pedal on the left side like every other truck they make...They didn't move it, just changed how it operated. 2021 you pull up; 2023 you pull down. At least on BL and WT. Just don't know why change it...
Probably because the action to turn on the e-brake is the same as the hood release and they're really close to each other.They didn't move it, just changed how it operated. 2021 you pull up; 2023 you pull down. At least on BL and WT. Just don't know why change it...
This ^^^Donāt slam them. Itās amazing that if you just push the door oh-so-slowly, it actually latches shut very nicely.
That could be it....Probably because the action to turn on the e-brake is the same as the hood release and they're really close to each other.
