Drove in 4H by Mistake - Damage?
RideEmCowboy
Portola Valley, CA
'95 Mustang,'08 Honda Civic,'03 15hh QH Paint mare
I neglected to turn 4H back to 2H after leaving the ranch last week. (I thought it automatically went back after the engine shut off.) So I drove around 40-50 miles, some freeway, before I discovered it. Did I hurt anything? Do I need to take it in to the shop?
JoshuaPrieto
Joshua
2021 Bronco, 2022 Explorer, 2022 F-150
no you are perfectly fine. I would avoid doing it frequently, but these aren't like how they used to be - where they'd get worn out prematurely.
That system can theoretically go 70mph on 4h, do I recommend it? No... lol
RideEmCowboy
RideEmCowboy
Portola Valley, CA
Thanks, Joshua. I probably did go over 70 for some of that, but it will never happen again, now that I know it holds that setting. I apologized profusely to Steamboat and gave him an extra special ceramic dry wash, window gloss, and tire dressing.
JoshuaPrieto
Joshua
Quick add-on, owners have reported a burning smell from doing 4wd at higher speeds with wheel spacers. This is because the increased friction from power going to the fronts... once again - will it hurt anything if you do it for a day of driving, no? Will it hurt if you do it everyday for a year? Probably, it would prematurely wear faster than someone who doesn't do that.
RideEmCowboy
RideEmCowboy
Portola Valley, CA
I -did- smell something. I thought it was brakes, but then it went away. My commute to the ranch is 8 miles--2 in town, 5 on fwy, 1 on dirt road. Did that twice, plus some errands, before I discovered the error of my ways. No wheel spacers AFAIK
dgorsett
colorado
F250, Mustang, Explorer
No sharp turning no frightening noises, you're good
I've done it myself in a few vehicles without catastrophe. Crow hopping into a parking spot is usually my first clue. :D
Raptor911
Raptor911
Broadlands, VA
I never put my 4wd vehicles into 4h unless I need it. Just because you are on the dirt, it does not mean you need to be in 4wd.
RideEmCowboy
RideEmCowboy
Portola Valley, CA
Thanks. I was aware I didn't need it, just wanted to try it. I had done it before, just to feel a little off-roady, but remembered to switch back to 2H when I got to the main road.
Tilzbow
NV
GM Sierra Diesel Pick Up
I once towed a 10,000# travel trailer 300 miles on the freeway with my 2006 GM in 4H. I put the truck in 4H to get the trailer moving out of the dirt area where it was stored and forgot to put the truck back in 2H after the 10 feet of loose dirt. I swore I’d never do that again but a few months ago I towed my 6,500# boat & trailer home 45 miles with the newer 2016 truck in 4H. I needed 4H to pull the boat out of the water due to slick algae growing at the bottom of the ramp then forgot to put the truck back in 2H after we stopped at the top of the ramp. Another dumb ass move and I didn’t realize I was in 4H until I made the sharp turn into the driveway. No damage was done this last time either, as far as I know.
So, I think you’ll be fine.
