feeble
Shawn
Yankton, SD
2022 Badlands, 1977 Cobra II Monroe Handler
I needed a way to remove and store my 2-door hardtop - here is what I came up with.. Everything was bought at Menards. I didn't use the brackets that came with the hoist and made my own. I was able to lag into three roof trusses with the 2 x 6 which should easily support the weight. The only thing I had on hand was some hardware and the materials that I made the hoist bracket out of - 1-3/4" square tube about 12" long and some leftover pre-punched flat bar from a garage door install. Cost me $220 after the 11% rebate including the hoist, ratchet straps, pre-punched angles and square tube, j-hooks, eye bolt, pool noodle, etc.
Took a little experimenting to find the CG front to back.
My ceiling is ~10'4" and the bottom of the hardtop is ~6'-8". I'm 5'-8" so this isn't an issue.
At some point, I'll likely add some means of storing the two removeable front panels.
Ford Bronco Electric top hoist for garage - my solution 86AC8EC7-4C60-4C34-A9F5-DDAC4B11E777
Ford Bronco Electric top hoist for garage - my solution 419C7BD9-6976-4F79-8C19-8DC32EFEECB1
Ford Bronco Electric top hoist for garage - my solution A398525B-5258-4CC9-8D47-02A856FC8D83
MayhemMike
Mercury
I really like the connector you have as the go between , and I might make one of those myself, but the ratchet straps, no way. Ten foot long nylon straps work for the two door top. I would lose sleep knowing my irreplaceable top was relying on those ratchets. Well done.
Gilligans_off
Vince
Canada
2022 2 Dr Bronco Badlands Sas/lux
how is the rubber seal holding up afterward? Is there any deformation? I'm just worried about creating leakage points for water/air after having the straps sitting on the gaskets.
feeble
feeble
Shawn
Yankton, SD
Don’t know yet, but that is definitely on my mind
jdawg
Julian
NewHampshire
Atlas/65Mustang
Stop messing around with the lift and get that hot rod going! Made me think about the Ford XB Falcon GT. What is it?
DudeBronco
Nashville
2021 Bronco Badlands, 2015 GMC Sierra
Stache12
Wisconsin
Ford Explorer, Chevy Cruze
Good ideas, I have a 4 door coming and I'm thinking of trying to utilize the 4 roof rack mounting points to hoist up the rear section.
Jroub21
Bruno
Wahoo
‘19 Raptor ‘17 Fusion
I have a gladiator, waiting on my bronco, of course. So instead of ordering a specific gladiator lift knowing I would have to possibly Jerry rig it once the bronco came, I made my own as well.
It ain’t pretty but it does work. I was right around $100 on the entire set up.
Ford Bronco Electric top hoist for garage - my solution 4F83FBD1-6CD2-4CAF-AD4E-93E5F1AF22C9
Ford Bronco Electric top hoist for garage - my solution 122AC97E-B8CA-4D42-BE1E-1209C6266C36
Ford Bronco Electric top hoist for garage - my solution 7E40B2D0-3A2F-406B-A385-26E6B9FD133C
Ford Bronco Electric top hoist for garage - my solution 10C05863-884D-419D-9B57-05BBDD60FBEE
Ford Bronco Electric top hoist for garage - my solution EE4C5448-6AFD-447C-92B0-550EA8441237
cmcbronco
Illinois
2012 f-150 FX4
Had a thread awhile back about this. Definitely critical to find the balance point of the top. Also you’ll want a safety catch just in case for some reason your lift were to fail. Especially if you park your bronco under it like I do lol.
Ford Bronco Electric top hoist for garage - my solution D5FCE1F4-44BD-41EF-914A-86D0CB9633C2
Ford Bronco Electric top hoist for garage - my solution 91309352-9FE9-42A6-9BC4-8E5CADC3F92D
Ford Bronco Electric top hoist for garage - my solution 69D4252F-07C8-4291-A431-63C97263448D
KANE COUNTY ILLINOIS
SAL
GMC YUKON
I love the color of your Gladiator! I was so close in ordering that same color late last year while my Bronco was sitting at MAPS! Lucky you! I need to install a hoist, too!
Jroub21
Bruno
Wahoo
Thanks. It seriously was the color that totally sucked me in. Went in thinking I was gonna get a wrangler out of frustration for waiting on the bronco, then this Gecko was sitting there and I fell in love with it.
I used to talk so much shit on gladiators too. 😬
Joemama
joe
St. Louis, MO
Hyundai Sonata
Where did you get the straps? the 2 middle ones that go to the winch cable?
atx_chance
Chance
Austin, TX
Previous: 1993 Bronco XLT
Some awesome looking broncos, gladiators, and fun toys in these garages haha. Nice job on the lifts
niterider006
State College, PA
Surprised no one has come up with a way to stick mounting points on the hardtop so you don't have to wrap straps around the whole top.
BottleShark
TJ
East Texas
Nautilus, Samurai, 12v Dodge, Fiero, Karma Ghia
I did the same, but mounted the electric winch in the attic and dropped the cable and remote through pipes.
My plan was to hook to the front bolt mounts for my front attachment point, so I wouldn't be on the gaskets. Any reason y'all didn't
