Factory Badland rockrails enough to support the weight of the car for hi-lift jacks?
beachman101
;pkl
So do you think the factory rock rails are attached well to the frame or are they just to protect the door frame?
You think you can lift the car on them?
AcesandEights
Ace!
Oregon
DR650
They'll support the weight of the vehicle; however, a hi-lift doesn't lift straight up (you'll create an arc), so I wouldn't use a hi-lift in (al)most all situations, and not at the door. You may damage a body panel.
beachman101
;pkl
thats what im asking , if the rock rails would be able to be hilifted and not damage the door frames
AcesandEights
Ace!
Oregon
DR650
Those rails will support the vehicle without damaging the door frames. I have doubts about using that jack though.
Natai
Sean
Sacramento
Nissan Sentra, Mercedes GLC
The factory rock rails are designed to support the weight of the vehicle without damage when moving over obstacles.
However, lifting a significant portion of the vehicle's weight at a single, small point using a hi-lift jack is a very different situation. The factory rock rails are attached to the body. Personally, I would NOT recommend using them as a jack point.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
As early as reveal night Ford was stating that each rail was designed to "support half the weight of the vehicle."
HoosierDaddy
What is the reason to jack from the rails?
A trail extraction? Do what you gotta do.
They are supposed to be able to hold the vehicles weight....per a Ford tech rep at one of the showings. (Whatever that's worth.)
Tire rotation? For safety's sake I would not advise it. Use the lift points the owners manual suggests.
AcesandEights
Ace!
Oregon
DR650
A rock rail must not only support the weight of the vehicle on a fixed point (a rock under the rail), but it must also protect the body panel when that weight is moving, coming down onto the fixed point. The rail will protect the body, can support the vehicle; however, the "dynamic" weight or force may tweak the mounting location.
It's just not a good idea to use a hi-lift there, imho.
HoosierDaddy
this is the only use of a hi-lift jack. Never understood people putting big ass jacks in their rig when there are tons of smaller jacks that work great
Because they look cool strapped across the hood, like the Baja pros do.
Duh......
:rolleyes:
Mickey21
Mickey
Round Rock, Texas
2021 Ford Bronco Wildtrak (Race Red)
Would trust it as far as I can throw it. The language is ambiguous and can mean many things when it comes to "supporting half the weight of the vehicle" as mentioned previously and as Ford has stated.
In what capacity, duration, direction, and to what failure, the rock rail itself in a protect once and replace? Too much to worry about especially when there is a frame nearby to actually lift from. Let's go with that first imo.
HoosierDaddy
Duh......
:rolleyes:
Come to think of it, I have one in storage somewhere.
Back when I started wheeling, they were sometimes a requirement for the club hosting the trail ride...or even the offroad parks safety requirements.
