Factory Fog Light Switch
ModifyMike
ModifyMike
Ford F450
Can confirm they work with the switch I used! Lights up on the dash as well correctly!
mds5917
New Jersey
'21 Bronco Badlands, '21 Toyota RAV4 Prime
Ford Bronco Factory Fog Light Switch 2A6CB488-A947-47A4-876A-62E893EA197D
The one thing I for some reason expected, but was not a feature of the switch, was for the fog symbol to "illuminate". Instead you see it on the screen (as long as you enabled that). Was like the expectation of the PRNDM being lit next to the shifter...
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Damn. I’m envious. Certainly one downfall of MY21 Black Diamond. I guess we’ll see if Capable Bumper being standard equipment with Fogs means the wiring will be standard across the board.
ModifyMike
ModifyMike
Ford F450
ModifyMike
ModifyMike
Ford F450
Beautiful work. Did you enable Forscan so your fog lights would work???
Yup, I did the changes mentioned earlier in the thread.
gizmohd
Darren
Bronco Sport (Wife), Bronco Badlands (Sasquatch)
Ok. The slow kid is confused again.
I thought the existing wired up connectors on the Bronco are female connectors and IF one did not want to alter the factory wiring, one would have to make the wiring from the fogs have a male end.
One could do so either by reusing the weather plugs (with alteration) that exist to seal off the harness connectors
Or by buying some of the correct male connectors with pigtails.
the connectors i posted would be the mail connectors that plug into the wiring harness ends that are for the fog lights
dcg2
Don
PA
Honda CR-V
Thank you that clarification. Definitely don't look "male" but hey its a different world than the one I grew up in!
P_Baff
Pierre
'12 VW GTI & '21 Ford Bronco
Is there a write-up of the exact items and steps needed to tackle this project? This is a good one.
Paul Gagnon
Paul
Sherwood Park, Alberta, eh?
I haven't read the whole thread but did you also change it so you can have the fog lights on with the high beams?
gizmohd
Darren
these connectors have the metal pins that insert into the other connector.. thats usually definition of male... lol.. inserting something into something else.. :)
Brianew
Seattle/Boise
69 Bronco, 08 Mustang, 2015 Wrangler
Sorry which switch did you get? I have the same rig. Only looking for the front fog...is it the M2DZ-11654-DA?
ModifyMike
ModifyMike
Ford F450
This part looks a little bigger than what exists in my First Edition. Is it the correct size? Would you happen to have a picture of what the unit looks like installed?
Yup that’s it, direct swap with the original unit.
