Final drive ratio - 4.46 or 4.7 better for this build?
KJR50
K
SoCal
I'm not telling U.
With the latest round of info released, 4.7 is confirmed not a no cost option.
In this scenario:
-2.7 with Auto-10spd
-35 someday, but 33 works for now
-daily, mostly highway driving, >75%
-fuel eco/range > power/accel
-most likely no rock crawling, definitely some off roading
Which ratio works better, 4.46 or 4.7? Engine will rev less with 4.46 running 35, what are the drawbacks?
KJR50
KJR50
K
SoCal
I'm not telling U.
Whoa did someone just edit the op
dwbronco
Manchester, NH
2018 F-150 King Ranch
In this scenario:
I'm kinda curious about this, too.
Mattwings
Matthew
Northville, MI
2021 Badlands Bronco
Who verified it’s a no cost option? I saw it on the order sheet and it’s only available on the SQ. Dealer is verifying, but so far, no dice.
shoelessjoe
2013 Chevy Cruze
I know B&P isn't the Bible but you can switch to the 4.7 and there is no upcharge. We shall see.
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
This should be more accurate than the B&P, but everything from Ford is suspect at this point:
Ford Bronco Final drive ratio - 4.46 or 4.7 better for this build? 1611143391627
Drex
Jake
4.7 would give about 5% more mechanical advantage at the cost of about 5% more RPM at the same speed, stock BL tire is about 5% less circumference that SQSH tire, so RPM world be roughly the same with 4.46 33 and 4.7 35. If you get a real 35 in the future, will slightly lower the mechanical advantage and RPM from stock. The heavier weight in the 35s of whatever flavor will increase the braking distance (gearing won't make a difference), slow acceleration, and decrease MPG one to two MPG at a guess. If you think you will fit taller tires in the future, get the 4.7 gears, will help turn the bigger tires. The MPG hit would likely be very small on the gears, but much larger with the taller tires, regardless of the year ratio you choose. (First I heard the the B&P being right over the order guide though, you sure about that?)
Mattwings
Matthew
Northville, MI
I asked and the dealer is asking as well, but from the order guide (while I was at the dealer) it is pretty specific as SQ only. It will be the factor that sends me to 2.7 vs. 2.3. I think the 2.3 would be very good with the 4.70 gears (probably without too, but....). If I hear something today I will update the post. I was hoping updated information was verified ordering of then option ?
PaBronco
PA
2020 JT Rubicon, 2022 F-150 Lightning Pro
The Rubicons have a 4:10 gear. Guys that run 35s with the 4:10 say it is just right, the off road die hards go with a lower gear (higher number).
Seems like a 4.46 gear would be plenty for most.
kodiakisland
Arkansas
Cool, of course that only matters if the Rubicons have the same transmission, transfer case, engine, etc. as the Bronco. Do they?
KJR50
KJR50
K
SoCal
I'm not telling U.
@kodiakisland post above, 4.7 listed available as SAS package only.
Spooled
Republic of Texas
CarbonSteel
Colorado Springs
2023 Carbonized Gray
I would disagree with that. 4.10s "work" with 35" tires, but are not optimum--the 8 speed auto in the Wrangler compensates for the 4.10 against the 35" tires.
