MyDogGoldie
Charles
SoCal
2.7L BD 4D
Amazing craftsmanship. Can you help me out with where the amplifier is mounted and how it receives its signal level inputs.
JP Fabrication
LA, CA
Bronco, VW R32, OBS Chevy Crewcab
I mounted the amp under the drivers seat. I grabbed the inputs by using a T-harness at the head unit brain
Braptrr
Sam
Metro Detroit
2022 Braptor, 1998 Panoz AIV
How do you like these focal 3 ways?
I’ve been debating those or the Morel carbon nano 3 ways. Does your amp have a built in DSP?
JP Fabrication
LA, CA
Thanks guys
and he's back for moar...
IMG_4516 by Jon Polo, on Flickr
IMG_4536 by Jon Polo, on Flickr
JP Fabrication
LA, CA
They are ok. They might be swapped out for the Flax series
JP Fabrication
LA, CA
Nice, as always! Kick panel location not doing what you want?
I got this idea from the Focal America Bronco. I was up for the challenge so I went for it. I also swapped out the 5channel for a SR 4.500, SR 1.500 amps and added another JL sub. There is no DSP yet. I saw that Metra is releasing a dash kit for aftermarket head units so that will prob be next
brtd
Iowa
23' BL, '15 LR4, '22 Beta 390-RS
Got a link to this "Focal America Bronco"? Google search lands me on this YT from soundsgoodstereo, but it might not be what you're referencing.
That series of videos was a big confidence booster for me before I tore my interior apart earlier this year.
In that build they toyed with the idea of adding some mid-bass to the doors, but I think they scrapped it. If there's a build that follows through with that concept I'd love to see it.
If there was a 5% improvement available in my system it would be a slightly lower xover to the sub from the front stage without sacrificing impact. The TM65s are phenomenal. But It would be really nice to add some TM8s into the mix.
But that would require more amplification and more DSP channels so please stop giving me ideas.
JP Fabrication
LA, CA
That is the build I'm referring to that Sage at Sounds Good Stereo did. JT from Anaheim did the door speaker build. Sage explains it here...
JP Fabrication
LA, CA
Breptar
Max
Los Angeles, CA
Mobile solutions FTW! I love fabricating too, but MTI will be my go to for my braptor. The mrs would kill me if I did everything from scratch. I take wayyyy too long doing things. I plan on running k2 power m’s (3-way actively) and k2 6.5 coax in the mti rear pods. i like that you use good equipment too down to the wire! Did you happen to test for grounds? If so, where did you find the best ground to be?
what did you use to bond the acrylic to the plastic in the dash? Epoxy With black pigment?
JP Fabrication
LA, CA
I grounded directly to the battery. 3M panel bond for the acrylic.
Congrats on getting the K2m's
mandark
Manish
Texas, USA
Ford bronco 2023
Focal Performance 165A3 3-way components (Tweeter+3" passive off ch 1&2, midbass active ch 3&4)
Focal ACX100 (head unit)
Audison SR 5.600 75WX4@4ohms+1X550W@2ohms
JL Audio 10TW3D-4
Knukonceptz Oxygen Free Copper power/ground 4g, OFC 14g/16g speaker wire,
Knukonceptz fuse holder and distribution blocks
IMG_1903 by Jon Polo, on Flickr
IMG_1904 by Jon Polo, on Flickr
IMG_1905 by Jon Polo, on Flickr
IMG_1897 by Jon Polo, on Flickr
IMG_1898 by Jon Polo, on Flickr
M noob at this. Anyways, does the voltage matter? From spec it seems like the audison amp requires 15v. It
For now I made a down firing sub enclosure. Future plans are I will make my own style JL Stealthbox
Ford Bronco Focal 3-way components, Audison SR 5.600 amplifier, JL Audio 10TW3D-4 subwoofer and custom enclosure 53337548301_b703fb9658_k
IMG_1569 by Jon Polo, on Flickr
IMG_1571 by Jon Polo, on Flickr
IMG_1573 by Jon Polo, on Flickr
IMG_1585 by Jon Polo, on Flickr
IMG_1586 by Jon Polo, on Flickr
IMG_1587 by Jon Polo, on Flickr
IMG_1610 by Jon Polo, on Flickr
IMG_1617(1) by Jon Polo, on Flickr
IMG_1909 by Jon Polo, on Flickr
IMG_1908 by Jon Polo, on Flickr
M noob at this. Anyways, does the voltage matter? From spec it seems like the audison amp requires 15v and my understanding is that the battery provides 12v
