Front / Rear Locker and Sway Bar Disconnect -- need for 3 functions to be separate?
Luterdan
Dan
Jacksonville
GMC Arcadia, VW Tiguan, Polaris Slingshot
Is there a need for all 3 of these features to be separate? Real question is, when you are on a trail and you start to lose traction or get into a tough situation, do you take time to say, I need to enable or disable X? or are you better off, just hitting all 3 switches and saying F-it, and the bronco will make it thru whatever. From the demos I've seen, they tend to start with front, then do rear, then do sway bar, but if you have the most flexibility with all 3, why not just do all 3 to begin with??? newer off-roader here, still waiting for my bronco.
Rex21c
Joel
Canby oregon
2016 fusion energi
From what I've driven, just turn to goat mode to mud/rut or whatever terrain your in and the Bronco will figure it out for you. if your doing it manually, most of the time having the rear locker engaged works fine, front lockers will help but will also kill your turning radius. The disconnect not really needed unless you need the flex. Once you get used to it all you don't really think about it as you just tap the button on the dash and keep going, it becomes muscle memory.
Jrod0486
Jarrod
Andrews, TX
2016 Ford Fusion
Some of the fun and enjoyment some folks get is the talent/skill it takes and doing some of the things with as few features used as possible.
Luterdan
Luterdan
Dan
Jacksonville
Interesting.
Theherofails
Thomas
Phoenix
You absolutely need those features separate.
Sway Bar disconnect has it's place but can increase roll in off camber situations, which makes you more likely to roll the vehicle. It absolutely helps when you need flex though. I use it constantly.
Front lockers should be used sparingly as it drastically increases turning radius as you should really never turn the wheel to it's limits with front lockers engaged.
Using front lockers when either tire could lose and then rapidly gain traction is a great way to snap your steering or blow up your transfer case or tie rod components.
Rear lockers are generally safe on slippery surfaces and should be the locker of choice for most beginner to intermediate skill level drivers.
The front locker can get you into trouble, so it's important to understand it's capabilities and limits. Use it as little as possible until you do. That button is by far the most likely to leave you with broken parts.
When do you use front lockers? When your rear tires are both on a slippery surface and fail to bite but at least one front tire has a firm grip. Engage 4L, Front locker, put the transmission in manual and lock it into first gear. Baby the throttle and let the torque pull you up and over the obstical.
Used correctly, front lockers are a great tool to have and you shouldn't fear it.. but it really is used on a case by case basis and shouldn't be the first thing you try.
Rivers90
Ben
california
xterra mx5
The sway bar disconnect gives you a smother ride over bumps so there is reason to use it with out even being stuck.
One of my friends with the sway bar disconnect, turns it off right when he gets to the start of the trail.
