Front Splash Guards/Mud Flap will NOT fit with Running Board
Yielar
Craig
British Columbia
2021 Ford F150 Lariat Powerboost
I keep checking back here to see if there is a good mudflap solution yet without having to cut my running boards. It really shouldn't be this hard.
I'm in the same boat as you. I'm leaning towards just ordering the Gatorbacks and cutting my side steps 2 inches or so and simply using silicone to refasten the front plastic caps instead of using the oem clips that will need to be removed.
vegetarianbarbarian
Ara
Novato, CA
2021 Ford Bronco 4dr
Sounds like wait and hope for some solutions. It is a good point about how many different combinations are out there, but would still like some affordable stock options from Ford rather than having to jump from a $50 flap to $450.
I've got a Wildtrak with SAS and the steps (which I'll probably replace anyways with LOD or GoRhino D6).
Seems like once you go SAS you automatically bomb out of stock fit on the $50 option, so mod is required.
  • Like
Reactions: Cat
vegetarianbarbarian
Ara
Novato, CA
I think steps just were poorly designed. All Ford had to do was shorten them slightly and for that matter raise them up to also have a pinch seam mount or at least cover that gap, which looks crappy.
also some mudflaps that aren’t $450 for the SAS package
Bronco cat
Carl
Morgantown wv
‘20 Explorer ST, ‘19 GT350, ‘21 Bronco Sport
I just bought the 50 dollar ford mud flaps and trimmed them to fit my sas obx and couldn’t be more thrilled with them. Had them in a huge storm and had nothing. Up the sides and they look pretty good.
Stonetree
Ron
Pittsburgh
2021 Bronco Wildtrak
Ford Bronco Front Splash Guards/Mud Flap will NOT fit with Running Board 37110ADA-7DE0-4999-A150-44B80E43C149
These look good. They don't hang down nearly as much as the overpriced Gator flaps. Those things nearly touch the pavement. Any pics on how you trimmed these to fit?
Bronco cat
Carl
Morgantown wv
I’ll pull something together for you. It wasn’t hard. I used a piece of cardboard to get the curve right then used a high speed cutting wheel. You can use the two lower mounting points and I know some people don’t mount the top but I did. I ended up using a plastic ford push rivet to secure it to the wheel flair which required a small hole that could be easily filled if I took them off and it’s in a place you would not be able to see.
John Auer
Captree Island, NY
Lincoln Nautilus, Ford Expedition
That looks great! Ford should re-engineer those running boards so owners don’t have to do a retrofit.
Jazer
Jessica
2.7 OBX
Hard to tell the steps were shifted back an inch
lines up nicely on either end
I like the "trail armor" too. Does it go under the door where you step in too? I was thinking about using my Ford Pass points to buy those.
Nice job.
tbohland
Thomas
Novi MI
2014F150
Nice job.
It does goes under the door and covers about 12” of the sill. The fit was ok but left some white showing on the bottom edge
Jazer
Jessica
2.7 OBX
Would you mind getting a picture when you have some time? I have clear door sill ppf already for mine (which is on its way), but im curious how it compares to having that there, and if those would scuff up the door sill as it is.
Bronco cat
Carl
Morgantown wv
Pics to help my fellow bronco family. It was much easier to modify the 50 dollar flap then cut down or reverse my running boards and I have had my bronco in two big storms with no adverse issues, no spray up the side. Also added pictures of the trail armor. Very happy I added it.
Jazer
Jessica
2.7 OBX
