Good iPhone Mount Using "Accessory Ready" point at top of Dash?
climb2descend
CA
15'F150
I have the 67 designs ball & arm. I tried it on the dash point, but couldn't stand having it that high and in my vision all the time, so I moved it down to the grab handle on the center console. I also replaced the grab handle with the base model flat plate.
Can you post a pic of yours this is what I was wanting to do.
BroncoT
SUV
BCKMRKR
James
NorCal
'22 Wildtrak 2-Door, '19 Miata, '15 M235i
I like the chargers not in my line of sight as well. I clicked on the link and it says pre-order..... how long did it take for you to receive the product?
thanks in advance
I would check with them. When I ordered, I got the grab handle mount (which was not listed as pre order), their tailgate Molle panel, and their cam-lock fire extinguisher (which are assembled to order) and it probably took a little over a week or so (they are on the east coast and I'm on the west coast). Their stuff is very well thought out, made, but certainly not the cheapest.
As for other comments about phone mounts (and dashcams and radar detectors), I'm done dealing with windows/suction cups/vents/GoPro mounts as they eventually fail (having the accessory point is a long overdue feature for vehicles). This is a great solution for the Bronco and have a similar mount that uses my Miata's empty cup holder slot.
Modad
Robert
2023 Badlands
This is the one removed from my Mojave then installed on the Bronco. . Doesn’t obstruct your view and places the phone closer to the user. Mods required was shorten the arm and ordering the 20mm ball from Amazon. Have been using this setup for 6 years.
Russ.Cere
Lux Sponsor (Level 2)
Russ
Washington State
modcrate.myshopify.com
The dash mount is 1/4-20 thread. That interface is really common for various camera mount systems. These are some 1/4-20 arms I bought for the latch plates designed. If you don't want to buy any additional mounting equipment you can search Amazon for "1/4-20 phone mount arms", or something like that.
*looks like this was answered a few times but you don't have to buy additional gear unless you want more mounting locations*
Merc4x4
steve
NJ
Can I load--permanently, if possible, my onX maps onto my computer screen? I have it on my Android (SamsungS21), but would like to have it on full (or fuller) screen. I have the Badlands Lux package.
Simple explanations for this computer-un-savvy Boomer or a link to understandable instructions would be a blessing. And thanks!
You should start a new thread, but while I’m replying…
OnX Android Auto
Ford Bronco Sync and Android Auto
PolarVortex
Bryan
Prince William, VA
23 Black Diamond, Craftsman tractor
Here’s another Tackform picture in the wild. Love this thing. Very solid, mounts perfectly and doesn’t take up too much space. Super modular if you need to add stuff. Not planning to expand it or anything though….Don’t have an iPad or Atari or Nintendo to mount :). Simplicity for me.
Ford Bronco Good iPhone Mount Using "Accessory Ready" point at top of Dash? IMG_6713
MacDonald_Photo
Jamie
Eaton Rapids, Michigan
2021 Badlands
Just ordered this but with the small arm on it.
How is yours holding up?
Also curious what holds it in place?
Thanks for any info.
Rumbloki
Alton
ATX
ZR2, 1973 Mach 1
Just looking for recommendations for a good rock solid iPhone mount that can screw into the "accessory ready" point at the top of the dash. I'm not looking to expand the number of points at this point but if I do would love an option that can be used with things like the Archetype Racing SLAP/BPM Accessory Mount. Most of the good options I have seen use a ball-type connector that screws in and then the arm for the phone mount goes on top of the ball. Any recommendations? Thanks!
RAM X-Grip and amazon ball. You can get different length arms or link them for more articulation. I like the short arm because it doesn't block switches or center display. The ball with the hex base doesn't block the Mabbet USB ports.
Ford Bronco Good iPhone Mount Using "Accessory Ready" point at top of Dash? 20231209_130734
Ford Bronco Good iPhone Mount Using "Accessory Ready" point at top of Dash? 20231209_130528
Ninjak
Miami
2021 GT500 2021 Bronco Badlands 68 GTA
I have the ram, but I took it off and I am using the Mabbet mount that attaches to the grab handles. I like the phone being to my left and out of the way. Also, I do not forget to grab my phone while being there.
PolarVortex
Bryan
Prince William, VA
Holding up great, solid....no movement of any sort. Really love it. The base mounts with a bracket that molds perfectly with the trim......where the black plastic on the dash meets the gray. The kit comes with a few different sizes of allen wrenches for each component. You'll like it.
MacDonald_Photo
Jamie
2021 Badlands
Good deal :)
I just wanted to make sure it wasn't some sort of double-sided tape or something.
C6ZZGT
Seattle
66 GT Mustang,94 Escort wagon,
I use a 67 desiigns in my bronco and jeep. They work amazing and quick in and out. I use the mount with the AR arms and ball mounts. You can get a single ball mount for uour accessory ready mount. I got the 3 post and love how solid it is. I use the other mounts for a mag mount and an Ipad
What length is that arm ?
