There is an extension available that allows you to place it much closer and doesn’t obstruct the windshield.Too far away and in line of sight of windshield
Can you post a pic of yours this is what I was wanting to do.I have the 67 designs ball & arm. I tried it on the dash point, but couldn't stand having it that high and in my vision all the time, so I moved it down to the grab handle on the center console. I also replaced the grab handle with the base model flat plate.
I bought the one that mounts to the Ford badge, but would buy this one if starting over. Get the MagSafe charging option for sure. Clean, convenient, easy to use, no goofy cylinder jutting out from the dash.If you don't want/need anything in your line of sight, this works great:
https://coursemotorsports.com/collections/bronco/products/direct-fit-phone-mount-ford-bronco-2022
I would check with them. When I ordered, I got the grab handle mount (which was not listed as pre order), their tailgate Molle panel, and their cam-lock fire extinguisher (which are assembled to order) and it probably took a little over a week or so (they are on the east coast and I'm on the west coast). Their stuff is very well thought out, made, but certainly not the cheapest.I like the chargers not in my line of sight as well. I clicked on the link and it says pre-order..... how long did it take for you to receive the product?
thanks in advance
You should start a new thread, but while I’m replying…Can I load--permanently, if possible, my onX maps onto my computer screen? I have it on my Android (SamsungS21), but would like to have it on full (or fuller) screen. I have the Badlands Lux package.
Simple explanations for this computer-un-savvy Boomer or a link to understandable instructions would be a blessing. And thanks!
Just ordered this but with the small arm on it.Here’s another Tackform picture in the wild. Love this thing. Very solid, mounts perfectly and doesn’t take up too much space. Super modular if you need to add stuff. Not planning to expand it or anything though….Don’t have an iPad or Atari or Nintendo to mount . Simplicity for me.
RAM X-Grip and amazon ball. You can get different length arms or link them for more articulation. I like the short arm because it doesn't block switches or center display. The ball with the hex base doesn't block the Mabbet USB ports.Just looking for recommendations for a good rock solid iPhone mount that can screw into the "accessory ready" point at the top of the dash. I'm not looking to expand the number of points at this point but if I do would love an option that can be used with things like the Archetype Racing SLAP/BPM Accessory Mount. Most of the good options I have seen use a ball-type connector that screws in and then the arm for the phone mount goes on top of the ball. Any recommendations? Thanks!
Holding up great, solid....no movement of any sort. Really love it. The base mounts with a bracket that molds perfectly with the trim......where the black plastic on the dash meets the gray. The kit comes with a few different sizes of allen wrenches for each component. You'll like it.Just ordered this but with the small arm on it.
How is yours holding up?
Also curious what holds it in place?
Thanks for any info.
Good dealHolding up great, solid....no movement of any sort. Really love it. The base mounts with a bracket that molds perfectly with the trim......where the black plastic on the dash meets the gray. The kit comes with a few different sizes of allen wrenches for each component. You'll like it.
What length is that arm ?I use a 67 desiigns in my bronco and jeep. They work amazing and quick in and out. I use the mount with the AR arms and ball mounts. You can get a single ball mount for uour accessory ready mount. I got the 3 post and love how solid it is. I use the other mounts for a mag mount and an Ipad
