Google Maps is so much better than factory. Not
Mlarv
TN
2023 Bronco/ 2022 F150/ 1968 Mustang
This happens pretty much every time I stat my Bronco or my F150. Both are up to date, both my wife's and my iPhones are up to date, Google Maps is up to date. I can select the 6 dots select Google Maps again and it finds me. If I hit find my iPhone while this is doing this, it is spot on. Some times I get a complete black screen, some times I get a gray screen with white squares (think Matrix). I have 5G service most of the time so it is not bad cell service. I have been driving a few hundred miles and towards the end of the trip it will do this. I don't live in the middle of the ocean. No the Fox News App is not causing it. Waze also does it when it wants to work. I will keep my Factory Nav which never has a problem knowing where I am.
GroovyGeek
Boyan
'23 Bronco BD
This could be a Ford thing. My AA works nearly flawlessly in my wife's GCL300. On my BD, with the exact same phone, it is a glitchy freezing POS that requires a reboot of the head unit at least twice a day. You pretty much have to start it on your phone and then never touch the Bronco screen.
V1Rotate
Bryan
Brevard, NC
2022 Wildtrak
Mine does this about 75% of the time too. iPhone 14 Pro Max up to date and connected to a ‘22 Wildtrak
Raptor911
Raptor911
Broadlands, VA
3 fords and no issues for me. Try removing your phone then add it back to your bronco.
Area51BS
Ron
Badlands non SAS 4dr 2.3
If there is ever a problem with something related to the touch screen it is a Ford issue. Sync is pretty bad. Been like this on my last 3 Fords. No issue whatsoever on our 2 VW’s.
cbrenthus
Western PA
'22 BadSquatch, '02 T/A
I don't know that I can help you, but my OCD is having a panic attack with the adhesive garage door openers :(
Mlarv
Mlarv
TN
I have removed it reinstalled it several times. My wife's phone does the same thing. If I go out of Google Maps or Waze and back into it they work almost fine.
When I was in TX for the Roadeo, at the hotel in Marble Falls it wouldn't start at all both mornings. Cell coverage wasn't as good there, so I figured it was causing this.
I am not worried about this currently. I posted this because every time someone says they want factory Nav, a lot of folks seem to ask why and proceed to tell us how much better Google/Waze are. You can down load the maps if you know where you are going ahead of time so you don't need cell coverage.
I have a felling my issue is I keep my phone in my lower pocket on my leg with out a clear GPS signal. My wife keeps hers in her purse on a hook on the back of the seat.
Mlarv
Mlarv
TN
Is it really OCD? Because if it was why would it be CDO? Letters matter
They are Velcroed there. I figure out of the weather out of sight for the most part, and easy to reach when needed. I can remove them with out leaving a mark.
Jdc
Jon
Massachusetts
Bronco Badlands
I've never had this issue. The vehicle choice wouldn't matter as it's the phone that is pushing to the screen. This could be some weird Apple + Google maps not playing well together issue
UncleTerry
Brad
Bronco Base 4dr
I get this occasionally as well in the bronco but I also got it on an aftermarket unit I installed in my previous vehicle. Leads me to believe it’s an issue with CarPlay/Apple or the Google maps app. I wouldn’t be surprised if Google doesn’t prioritize bugs for Apple CarPlay.
Also make sure your Google maps app is updated. I had an app update today. Version 6.69.
garrybooker
Andrew
Pittsburgh
2023 Outer Banks (production week 5/22)
Was looking for a similar answer this morning..
this happens 100% when my app isn't open on my phone
It happens 0% of the time when my app is opened on my phone.
I just set up a Automation for Google Maps to open when connected to carplay.
Hopefully that fixes issue.
BlueBronco
DFW
Gonna chalk that up to CarPlay issue. I have used Google Maps on Android Auto on Sync3 & Sync4 on various Fords since the introduction of AA without issue.
mhtucker78
Matthew
VA
2023 OBX Bronco
Took my first (short of my pickup drive PA->VA w/ no issues) longer road trip to OBX this weekend and had my wireless carplay drop out a few times about an hour into the trip. Both ways. I am liking the inbuild navigation the more I use it and its integration into Amazon (don't use Siri) is pretty nice too. There are a lot of POI on it.
KillerPenz
North East
Must be an Apple thing, Google Maps and Waze both work fine on my android phone in my Bronco 🤷‍♂️
