UPDATE: Unfortunately things got worst. The Bronco completely died today (Nov 26, 2023) while going to get tacos 2 miles from home. This post has all the details and a video to proof it. This car only has 9k miles
I bought a used 2022 Bronco WildTrak with 8k miles on it. I love the exterior and interior looks of the vehicle, the comfort, etc except I just can't trust the car off-roading anymore. It just hasn't been reliable.
I went off-roading solo in one of the desert trails outside Vegas. Its an easy trail (rated 3/10 difficulty on ONX ), total driving time was supposed to be about 2 hrs to and fro and its mostly sand and gravel with a little rocky steep patch not longer than 10 feet and about 15 degrees incline. I drove in and it was all smooth but on my way back my Bronco suddenly reported an error, "4x4 Temporarily disabled". There was no obvious signs that could have caused this. I didn't hit/scrape any rocks and had only driven about an hour. Due to this I wasn't able to climb a small sand hill because I never had enough traction. Since the hill was small i decided to drive around it which meant going of the trail, its the desert so I wasn't blocked by any trees but the path was rocky and with 2WD it was quite the ordeal. I'd keep lifting a tire in the air, stop, then stack rocks under the tire so I could continue. This would have been super easy with 4WD but due to this my return which was to be about an hour took 3 hours.
I have tried to Google the issue, it can be caused by several factors and overheating is one of them. It was 70 degrees Fahrenheit out and I only drove for about an hour with my max speed being 40 mph, no hitting rocks or super steep climbs. If that alone is enough to overheat the 4x4 system how can I even trust this thing to go overlonding?
If its not overheating what can cause an 8k mile bronco fail this bad at the one thing its supposed to do? Have any people dealt with this, I wonder how common it might be? I've seen threads in other forums about this without the driver even going off-road.
Funny thing is the 4x4 system was renabled about 15 mins after I got out of the desert and was back on the highway.
EDIT: Based on how often this happens and in not so challenging situations I think the statement "A jeep will take you there, but a Toyota will take you there and back" should be updated. It should include the fact that a Bronco won't even get you there. This car seems to have been designed for mall crawlers.
