Great Southern Bronco Deal!
ColoradoGuy
Congrats on putting together an excellent offer. You will do very well with that.
One recommendation is to be as transparent as possible and enjoy the ride.
Mattbar1
Mattbar1
Truck
That’s impressive...
Get ready for the swarm of questions
I will do my best. But my answers don't mean much. Questions really should go to Rob!
Rydfree
Benny
Alabama
Is the Lifetime Powertrain warranty limited by how long the original owner has the vehicle or how long Matt Bowers Ford stays in business ?
Serious question . Will it remain in effect with other ASE certified repair centers if the delership changes ownership ?
Mattbar1
Mattbar1
Truck
LIFETIME WARRANTY FAQ
WHICH VEHICLES QUALIFY FOR THE MATT BOWERS LIFETIME WARRANTY?
The Warranty applies to all new vehicles other than those for commercial use. It also applies to select pre-owned vehicles that are 5 calendar years old or newer, with 80,000 miles or less, that have passed our Lifetime Warranty certification program and a CarFax or similar inspection.
HOW LONG IS THE MATT BOWERS LIFETIME WARRANTY REALLY GOOD FOR?
The Matt Bowers Lifetime Warranty is valid for as long as you own the vehicle - for Unlimited Miles, Unlimited Time.
HOW MUCH DOES IT COST?
Zero. Our goal is to build "Customers for Life" so the Matt Bowers Lifetime Warranty comes standard with every qualifying vehicle meeting the criteria above, and the warranty is included at no charge.
IS ANY EXTRA MAINTENANCE REQUIRED TO MAINTAIN THE MATT BOWERS LIFETIME WARRANTY?
No extra maintenance is required. You must simply follow the manufacturer's Recommended Maintenance as referred to in the owner's manual.
WHERE AM I COVERED BY THE MATT BOWERS LIFETIME WARRANTY?
The Matt Bowers Lifetime Warranty is good at any ASE repair facility in the United States and Canada.
DO I HAVE TO HAVE ALL MY SERVICE COMPLETED AT THE MATT BOWERS DEALERSHIP?
We would love for you to come back to us for all your service needs, but no, you are not required to come here to maintain the warranty. You simply must perform the Manufacturer's Recommended maintenance and keep your records. It's that easy!
IS THE MATT BOWERS LIFETIME WARRANTY TRANSFERRABLE IF I SELL THE VEHICLE?
No. The Matt Bowers Lifetime Warranty stays with the owner as long as they own the vehicle.
ARE THERE ANY HIDDEN FEES?
No, there are no hidden fees. Matt Bowers provides this warranty as an added-value to our customers for doing business with us.
WHAT'S COVERED UNDER THE LIFETIME WARRANTY?
The components covered will be the exact same as the Factory "Powertrain" Warranty and include:
ENGINE
  • Cylinder block
  • Cylinder head(s)
  • EGR valve
  • Engine mounts
  • Exhaust manifold(s)
  • Flywheel or flexplate
  • Harmonic balancer
  • Intake manifold Intercooler
  • Oil pan
  • Oil pump
  • Ring gear
  • Rotor housings and internal parts
  • Timing chain(s) or belt(s)
  • Timing chain or belt tensioner(s) and timing chain or belt cover
  • Timing gears
  • Turbocharger or supercharger housing(s) and internal parts
  • Vacuum pump Valve cover(s)
  • Wastegate Water pump
TRANSMISSION
  • Cooler and metal cooler lines
  • Manual clutch assembly slave cylinder and master cylinder
  • Torque converter
  • Transaxle case
  • Transfer case and internal parts
  • Transmission case
  • Transmission mounts
  • Vacuum modulator
DRIVETRAIN ASSEMBLY
  • 4x4 locking hub
  • Axle shafts and bearings
  • Center bearings and drive shaft yokes
  • Control processor and sensors
  • Drive shaft(s)
  • Final drive and axles housing(s) and internal parts for both front- and rear-wheel drive
  • Four-wheel drive engagement actuator/motor
  • Solenoids
  • Traction control linkage
  • Universal and constant velocity joints
Brehus
Josh
Santa Rosa Beach
SUV
Looks like I might have a new Dealer!
Its hard to pass on a Free Lifetime Powertrain warranty. I will consider them as an option at this point but only have 1 dealer change remaining and there's still time for more dealer incentive packages to make their way to the forum.
Mattbar1
Mattbar1
Truck
From FORD FAQs:
I already changed my dealer once, can I update my dealer selection again?
Yes. Customers may reach out to Ford Customer Support at (800) 334-4375 for assistance in updating their dealer selection through January 31, 2021. In changing dealers, there will be no impact to a customer's reservation ID, vehicle details, or the associated timestamp.
Tenny
Drew
Houston, TX
C8 Corvette, Volt, Jeep XJ, Stealth RT/TT
Looks like I'm going to have to change my reservation... my dealer won't budge from MSRP.
Used2jeep
Massachuvian
2007 Crown Vic P71
Ford Bronco Great Southern Bronco Deal! 0aa6d6608b3848aba8e953c01f652ed4_2547x662
ENGINE
  • Cylinder block
  • Cylinder head(s)
  • EGR valve
  • Engine mounts
  • Harmonic balancer
  • Oil pan
  • Oil pump
  • Ring gear
  • Timing gears
TRANSMISSION
  • Torque converter
  • Transaxle case
  • Transmission case
  • Vacuum modulator
DRIVETRAIN ASSEMBLY
  • 4x4 locking hub
  • Drive shaft(s)
  • Solenoids
The turbos are covered? Timing chain too. Hmm. OK, let's just say that the machine starts to consume oil. What is the situation there - assuming valve seats are ok?
