Hard top hoist with 2 contact points (pics)
TXBrian
Dallas
2022 Bronco
Was wondering if just clipping 2 flat hooks on would be sufficient to hoist the hard top (4 door) so threw a strap over a beam on my patio and lifted the hard top up.
Seems like it would work fine long term.
My thought is to use 2 24”-30” straps with a flat hook on one end and a ring on the other end. Then simply connect the rings to a manual or electric hoist.
Thoughts?
EL in NH
Ernie
New Hampshire USA
2dr Basesquatch, 2005 HD springer,2010 sporty
I Don't see why it wouldn't work. Though I would not store it that way. I would have concerns about the top flexing and taking a set. It might be rigid enough so this is not a concern. I don't really know as I'm still waiting on mine.
TXBrian
TXBrian
Dallas
2022 Bronco
Seems like there is extra material on the point where I hooked .
But may just use it to get it lifted then throw some extra straps on for longer term storage.
TXBrian
TXBrian
Dallas
2022 Bronco
Installed an electric winch in my attic today.
$129 off Amazon.
Partsam 440Lbs Lift Electric Hoist Crane Remote Control Power System, 110V Electric Hoist Zinc-Plated Steel Wire Overhead Crane Garage Ceiling Pulley Winch w/Straps (w/Emergency Stop Switch) https://a.co/d/aaUHDF3
Waiting on straps to get here to start that part of it.
Plan is to use 2 flat hooks with straps to get it hoisted then will add some safety straps to ceiling once it’s lifted for peace of mind.
Kenith
Kenny
Let us know when the flat straps arrive and which ones you used, this seems like a great idea!
TXBrian
TXBrian
Dallas
2022 Bronco
Got the flat straps in today and system works great.
Hooking on towards the front of the back rail is almost perfectly balanced .
I put some felt under the flat hooks for piece of mind.
Now to just add some hooks on the ceiling with some tie downs or something as a fail safe for when hung from the ceiling .
EL in NH
Ernie
New Hampshire USA
Ford Bronco Hard top hoist with 2 contact points (pics) DC47BF92-B4FD-40B5-849C-6D31E4548F40
How the heck did you find those? looks like those straps were made for this job.
TXBrian
TXBrian
Dallas
2022 Bronco
I found a company that custom makes straps and tie downs. The one in the pic was part of a Y harness they sell and I just used part of it.
I also had them make me 2 straps that are 30” long with a flat hook on one end and a 2” ring on the other.
But the 2 rings wouldn’t quite fit on the hook on my winch so I didn’t use them.
They will make whatever size and config you want.
Think I’m going to have them make me one more config shortening the straps to 24” so I can get the top a little higher, joined together with the 2” ring at one end and 2” flat hooks on each of the other ends.
https://customtiedowns.com/search.php?q=11691-G2.5
EL in NH
Ernie
New Hampshire USA
Perfect!
CamptownBD
Ike
Chicago
Bronco Basquatch
This is excellent. Thanks for posting. How long are the straps pictured from the Y strap kit (the ones in the photo)? If they are around 2 feet long on either end, could another set of 3 footers for the front slot be used allowing you to throw the middle rood piece on top. I am thinking the longer front straps may help keep the balance.
