HELP-- Wiring LEDs To Upfitters with Relay Harness?
F1NDx
Detroit, MI
Essentially I got LED pods that I want to connect directly to the AUX switches. They have 2 modes, Amber and white so its a 3 way switch. I don't want to use the provided switch on the harness (which also has another fuse+relay attached). Anyone have a clue I can install these? Pics of harness added
Ford Bronco HELP-- Wiring LEDs To Upfitters with Relay Harness? Screen Shot 2022-01-30 at 2.19.37 PM
F1NDx
F1NDx
Detroit, MI
Just cut the harness before the relay and wire to 2 of the upfitter wires , and of course ground the 3rd.
Yes, thats is exactly what I did. I should have specified that.
However, no power at all. Prior to even cutting the harness (before the relay), I tested the leds on a battery to make sure they were working, so not a defect.
Copperhorse73
Justin
Mooresville, NC
2022 4 door Wildtrak
it should work fine assuming u got everything wired correctly to the switches and grounded properly. Iā€™ve cut up many a fused relay cable in my day and never had an issue. If u are 100% sure u did, Iā€™d get a voltage meter on the upfitter wires to be sure u donā€™t have an issue, or check for blown fuse
Nolabel
Van
Mesa Az
The switches only work with the Key in the on position. I too cut out the relay and connected the 2 hots to the upfitter switch 6 and the 2 grounds to the body ground.
RunJB
KS
Toyota FJ Cruiser
So to wire cube lights in a Bronco with factory switches there is no relay needed, correct?
Copperhorse73
Justin
Mooresville, NC
Correct, relays and switches are all part of the Aux switch package, simply wire positive wires to the aux wires in the engine bay, and ground to any existing ground. Easy peasy
RunJB
KS
Toyota FJ Cruiser
Thank you, much appreciated!
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Saddly those kinds of kits don't include the proper wiring harness for a Bronco. They over complicate your installation with their generic harness.
You can just cut the switch off and use the hot legs from the harness. That's all you care about. You're cutting the harness back before the relay. So you'll essentially have 2 pigtails (or 2 plugs that go into 1 pigtail for you to connect to your upfitters)
EDIT: I see this is an OLD post. Weird a lot of OLD posts are getting brought back up to the top today
TeamUSA
Jeremy
Ohio
2018 Ford 150 Supercrew
Does this work. Iā€™m about to try as I donā€™t want to order a new harness and restring the entire set again
F1NDx
F1NDx
Detroit, MI
Yes, it works. Still working flawlessly to date.
