- Marcus
- Jun 13, 2021
- 6
- 861
- 1,201
- Laguna Woods, Ca
- Bronco, Triumph Thunderbird Commander 1700
- Base
I bought three pairs of 3" amber lights (generic) and some Nilight's, a pair of 3" ditch lights with a 14" light bar, plus some rock lights (lights & harness not shown) and amber grill lights (connects to parking lights fuse, so not shown). I'm going to mount the 6 amber in the mod bumper three per side (15 amp aux) and the 2 Nilights white 3" (longer one shown below) as ditch lights on the "A" pillar. Light bar on a bull bar. All lights came with what looks to be nice wire harnesses.
Each set came with a nice harness complete with on/off switch, relay and have fuses and I'm hooking up to my aux switches.
My question(s): From what I've seen on install videos, I "ONLY" have to wire a hot wire to an aux switch wire of the correct amp and a ground, seems too simple and a waste of good harnesses? And yet simple also works for me.
Do I cut up these harnesses and butcher to use, using only the red and black wires? This gives me the lead wire from the switch to where it splits off to each light. I'm assuming 2 amps per 3" led and and the three white lights, (2) 3" & the 14" bar should be ok on a 10 amp, 4 ,mps for the 3" with 6 amps left for the small bar.
or save harness for someone else to use, I have extra ditch light mounts too, two pair the $25 kind on Amazon.
or
Do I just disconnect the power switch (cut off connection for another use, and wire the red/black to the aux switches and ground using the rest of the harness saving/including relay and fuse? Are redundancy in relays and fuses OK? Help or hindered to circuit?
If the answer is simple wire from the aux switches, one hot to switches and a ground, then I'm buying wire and connectors to simplify and will have two sets of ditch light brackets along with the wiring harness (four, one for three lights) I could trade/sell to pay for the new stuff.
or
