- Brian
- Sep 14, 2023
- 13
- 1,246
- 1,804
- Central CA
- '23 BB 4dr 7MT, '22 BSport OBX, '87 B-II XL
- Big Bend
So, I do a lot of driving in the mountains with a 7MT. You kind of get to make the decision on where you want the engine sitting.
A lot of hills and the speeds you drive around here, you get to make the choice - do I sit in a lower gear with higher engine RPM, or a higher gear with more turbo boost?
Aside from the fact that the engine is more responsive in a lower gear - that isn't necessarily what I'm asking. Some of these are long stretches on a relatively decent grade - 5-10%. At 50mph I'm either at around 3k RPM in 4th (and 3-4psi boost) or sitting at around 15psi boost (at about 2.5k RPM) in 5th.
Which is better for the engine, or does it make much of a difference?
The manual recommends the following:
Just curious what people with better aptitude for these things than I posses think about this.
If I go by the manual, the engine drags badly at under 2K RPM - fine for cruise control on a long stretch of flat highway, but doesn't work at all in the hills/curves. I do usually shift around 3.5k RPM or so, but just cruising i'm usually closer to 2.5K RPM and rarely under 2K unless it's down in the valley on something long and flat.For best fuel efficiency when driving your vehicle, shift to the next gear by 3000 RPM.
Shifting at a higher RPM such as 3000-6000 RPM can increase the performance capabilities of the vehicle. However, higher engine and transmission speeds can increase wear and reduce fuel economy.
When downshifting your vehicle, always shift at the lowest engine RPM possible to match your driving conditions. This is usually under 2000 RPM for all forward gears, except for downshifting into the crawler (C) gear which you should do below 1500 RPM.
