Hoss 3.0 and On-Road Performance
ahunia
Adam
Chicago
Will the Hoss 3.0 package improve on road performance (i.e., softer ride) or make the ride stiffer?
BigMeatsBronco
Allan
2021 FE 2 door
On road performance is NOT the goal here...
However the newer broncos do have a rear swaybar which will improve handling and reduce body roll.
Also a rear swaybar does allow for slightly softer springs generally.
The biggest difference I'm guessing will be in how the shocks are able to dampen bigger bumps easier, and this could allow the factory to use a tad less preload on the springs. (And maybe even shorten the bump stops a tad)I'm wishing and hoping this package includes the slightly longer, ranger raptors UCAs and LCAs (with same or similar fox shocks) These have been in production in Thailand for several years!
MileHighWT
Denver, CO
2022 Oxford White Bronco Wildtrack
It is a significant improvement under all conditions.
ahunia
Adam
Chicago
Thank you for the responses. I ordered before the 2023 model price and adding the feature moved the base price by $1,750, in addition to the upgrade fee for the Hoss 3.0. I don't think it is worth it.
El Bronco Blanco
Matt
Scottsdale, AZ
2013 Ford Explorer XLT, 2021 Mazda CX-9
That's not how it works. There is a rebate involved. If you are already a Wildtrak order and not changing your package (LUX/HIGH/MID) you will supposedly get a rebate for the difference between the MY22 pricing and MY22.5 pricing that pops up on the DORA after its changed. It's not confirmed, but that is how it is supposed to work, I guess.
ahunia
Adam
Chicago
Thank you for the intel. I'll try again and specifically ask the dealer about the rebate.
El Bronco Blanco
Matt
Scottsdale, AZ
My back and forth with my dealer:
Ford Bronco Hoss 3.0 and On-Road Performance Screenshot 2022-04-01 154430
Ford Bronco Hoss 3.0 and On-Road Performance Screenshot 2022-04-01 154504
Granted, Ford can change tomorrow how this works, and my dealer could have been wrong. But the consensus on the site, seems to agree with the rebate situation as my dealer replied.
Bronco Bri
Canton, MI
2017 Ford Fusion, 1966 Mustang
Anyone heard when production begins for Wildtraks with the HOSS 3.0 option? I had read summer but wanted to see if an actual date was published.
El Bronco Blanco
Matt
Scottsdale, AZ
I'm hoping summer (June/July) and that scheduling sucks up some HOSS orders to get the "new thing" out to showcase for MY23 order banks to open. Nothing concrete though.
FlyingScot
Tomball, TX
2022 Wildtrak 4dr
There's at least one order with the HOSS 3.0 that has a window sticker for the April 4th build week
mehkanical
Russia
2022 Bronco
I'm just wondering if people will still be snapping tie-rods.
mehkanical
Russia
2022 Bronco
Snapping tie rods? The HOSS package includes the upgraded heavy duty rack & pinion and tie rods.
The question; is ~30% stronger tie rods strong enough? Aftermarket solutions provide larger diameters and wall thicknesses. I would prefer a factor of 2 or 3 on strength. Broncos aren't going to outer space so ~10lbs+ of weight won't be a problem.
Joestac23
Joe
Ohio
Jeep Compass
I added the HOSS 3.0 and my scheduled build week is 5/16. Hope that helps answer your question.
