Not yet, I really wanted to try out the 37’s without the JKS kit first to test DV8’s claim that 37’s fit without lift or other modifications at full articulation on stock Sasquatch suspension. Unfortunately my 37’s have been pushed back to April per General Tires… I’m looking at other options though to get something sooner. My neighbor has JKS installed on a stock Sasquatch with 37’s and he clears with minor rubbing at full articulation. Nothing bad though and we rip it up on all sorts of trails.Did you ever get the JKS kit installed?
Any updates, or bottom line it doesn’t clear 37s without rubbing if you go off-road and use the full range of OEM Sasquatch suspension articulation?
I am not a fan of the fender liners lol. Not only for the reasons listed in this video (false advertising for fitting 37’s). But they are not lasting. My DV8’s are not holding up to wheeling. Brackets are snapping off and bolts snapping out. My rears are about to fall outFor the money...the DV8 fitment looks very poor.
I had the JKS kit installed which is supposed to remove that plastic piece. Unfortunately the shop that did the install didn’t install that part and threw that portion of the kit away haha.As soon as I saw it was multiple pieces....I knew they were a no go.
Do you rub that plastic support behind the front tires? I rubbed the factor liner off...not sure if the tires are hitting the plastic however. I did shave the drivers one down a bit.
I may knock them down with a flap disk. Hopefully that provides some clearance.I had the JKS kit installed which is supposed to remove that plastic piece. Unfortunately the shop that did the install didn’t install that part and threw that portion of the kit away haha.
My 37’s have been rubbing on it even with 0 offset and lift. I do hit whoops hard though, jump it and hit the rocks. That plastic piece has been “self clearancing”
