How much poke, or offset can up go with no rubbing on Bronco Raptor???
swamp2
I run 17X9 w 0 offset on Nitto 38x13.5 Trail Grappler and RPG 2.25 collars. My tires stick out about 1.5" from the fender at it's most outer point and no rubbing yet. I haven't tested it at full articulation but thought I share this for what it's worth.
Looks fantastic. Very curious about clearances F&R and under steering lock (i.e. entire wheel envelope). Let us know if you can test that out on the trails. Collars won't affect total wheel envelopes, right?
NatureMan
United States
So, I have a little bit of fender flair rash that would not have happened with some poke on my tires. I see that +18 is a popular choice for back spacing instead of the factory +34. That is moving the rim out .629" . 0 offset would be 1.338" out farther.
How far out can you go? With Stock tires? With 38/13.50 tires? I really plan to run stock tires till near the end of their life then go to the 38/13.50. I have looked same at new wheels, but really like the looks of the factory bead locks. Smallest wheel spacers I have seen are 1.25"
Looking for any information that can help. I do not want any rub at all, I use full articulation off road.
derichio02
Bo
Southern California
Bronco Raptor, Bronco Wildtrak, Maverick, Tesla M3
Does anyone know what size RTR EVO 6 went on this Raptor? This looks just about right from the flares
Looks like 17x9 +18. That puts the wheel pretty flush with the fender. Tire pokes out past the wheel of course.
Here is +18 on a 12.5
